How Can I Fix This, Wing Window Out of Alignment |
motorvated |
Jun 12 2014, 09:02 PM
Member Group: Members Posts: 281 Joined: 13-February 13 From: Colorado Member No.: 15,519 Region Association: Rocky Mountains |
The wing window on the passenger side door of my car doesn't line up properly with the angle of the windshield, leaving a gap at the top. I have been inside the door and tried loosening the two bolts that seem to hold the vertical channel in place. Doesn't seem to be an adjustment there. Anyone know if it's possible to get this thing lined up. Door is very straight in opening with good rear gap. Driver's side is OK. Pictures below.
914Sixer |
Jun 12 2014, 09:12 PM
914 Guru Group: Members Posts: 8,906 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Yes, it is easy. Pull door panel and loosen 10mm bolt under vent window. Go to the bottom out side of door and loosen 13mm nut. Spray bolt that holds window post with some PB Blaster. You are now ready to move the post in by turning post screw adjuster in or out as needed. When aligned where you want it tighten bolt and nut.
motorvated |
Jun 12 2014, 10:48 PM
Thanks Mark. I saw two nuts down on the bottom of the door, just didn't figure out how they worked. I'll take a stab at it this weekend.
NORD |
Jun 12 2014, 11:16 PM
Senior Member Group: Members Posts: 1,505 Joined: 14-September 04 From: Lynden Washington Member No.: 2,756 Region Association: Pacific Northwest |
Yes, it is easy. Pull door panel and loosen 10mm bolt under vent window. Go to the bottom out side of door and loosen 13mm nut. Spray bolt that holds window post with some PB Blaster. You are now ready to move the post in by turning post screw adjuster in or out as needed. When aligned where you want it tighten bolt and nut. I agree. This is how the book suggest it be done. It may be in the tech 600 book. |
rhodyguy |
Jun 13 2014, 01:58 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
In the Haynes for sure.
Lo-Fi Version | Time is now: 10th June 2024 - 12:41 AM |
