vin number stamped in body ?, refinish |
seareef228 |
Jun 18 2014, 12:00 AM
Newbie Group: Members Posts: 32 Joined: 13-May 14 From: so cal Member No.: 17,347 Region Association: None |
Hey guys my vin was painted over . How was it originally ? primer??
Attached thumbnail(s) |
Tom_T |
Jun 18 2014, 10:52 AM
At the factory it was just masked out with tape when painted & left bare metal to stamp the VIN.
You can recreate that look by scoring the paint with an Xacto knife & straight edge along the faint flat area, then masking the outer area, & then using Q-tips & acetone to carefully bubble & peel the area to bare metal. However, you'll want to immediately protect it with something like either clear Rustoleum, or else regularly give it a thin film swipe of WD40/3-in-1 Oil/etc. |
seareef228 |
Jun 19 2014, 11:08 AM
At the factory it was just masked out with tape when painted & left bare metal to stamp the VIN. You can recreate that look by scoring the paint with an Xacto knife & straight edge along the faint flat area, then masking the outer area, & then using Q-tips & acetone to carefully bubble & peel the area to bare metal. However, you'll want to immediately protect it with something like either clear Rustoleum, or else regularly give it a thin film swipe of WD40/3-in-1 Oil/etc. Thank You Tom just the answer I was looking for |
1970 Neun vierzehn |
Jun 20 2014, 12:04 PM
Advanced Member Group: Members Posts: 3,199 Joined: 16-March 06 From: cincinnati, ohio Member No.: 5,727 |
here's an OEM finish.....
Attached image(s) |
seareef228 |
Jun 20 2014, 10:17 PM
davep |
Jun 30 2014, 09:47 AM
914 Historian Group: Benefactors Posts: 5,154 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
I'm certain the factory used some kind of a clear coat to protect the area. On the 911 they generally used a brush with some black paint to protect it.
Lo-Fi Version | Time is now: 9th June 2024 - 07:28 PM |
