> JUTE carpet padding, what weight?
malcolm2
post Jun 24 2014, 08:02 PM
Can anyone give me some feedback on the best weight to buy? eBay Jute
This eBay store has several weights. This one is the heaviest at 40 lbs. My car still had this stuff in it. My guess is it is 20 or 10 lb stuff. I am using the b-quiet ultimate 1st. Figured I'd add this stuff too.
I figure it will add some insulation, sound dampening and soften the carpet. Pretty cheap too.
Thoughts?
Clark
Replies(1 - 8)
Sfreeman615
post Jun 24 2014, 08:10 PM
QUOTE(malcolm2 @ Jun 24 2014, 09:02 PM) *
Thoughts?
Clark
I'd go with the 20 if you are using the b-quiet as well! That's a really good price!
malcolm2
post Jun 27 2014, 10:07 AM
bump for JUTE input.....
(IMG:style_emoticons/default/poke.gif)
damesandhotrods
post Jun 27 2014, 11:17 AM
At half an inch it’s kind of thick. I could see it helping to keep heat and cold from transmitting through the floor boards. I’m just not sure that it’ll make much difference as far as sound. As you drive along, there isn’t much noise generated under the car, the noise is coming from the engine behind the firewall.
McMark
post Jun 27 2014, 09:18 PM
914 Freak!
Zero.
You asked. (IMG:style_emoticons/default/smile.gif)
malcolm2
post Jun 28 2014, 07:25 PM
QUOTE(damesandhotrods @ Jun 27 2014, 12:17 PM) *
When i pulled the rear panel it had jute glued to it. So sound and heat blocked from the upper firewall. My minimal study has led me to understand that stuff like the stick on tar panels knock down the high freq rattles and the thicker pad like jute takes care of the lower freq sound. Any sound engineers out there? People will put a patch of B-Quiet on the outer skin in the door. Not the full coverage, just a patch. It lowers the high freq vibrations on that large flat panel.
damesandhotrods
post Jun 28 2014, 08:19 PM
Glued to the rear panel? I’d be concerned about the jute fiber trapping moisture and promoting rust. Jute fiber carpet padding was the go to insulation back before the modern insulations hit the market. Jute fiber’s heyday was in ‘70s van conversions.
McMark
post Jun 28 2014, 09:09 PM
914 Freak!
QUOTE(damesandhotrods @ Jun 28 2014, 07:19 PM) *
Ding ding ding! (IMG:style_emoticons/default/agree.gif)
malcolm2
post Jul 1 2014, 08:59 PM
QUOTE(McMark @ Jun 28 2014, 10:09 PM) *
wouldn't carpet do that? isn't the perlon stuff like a scotch brite pad... (sponge)? the black crap that the factory put on the floor did not help, it directed water straight to the hinges and the center "hat" channels, not to mention trapping it against the depressions in the floor panel, so nothing is going to stop water except a garage.
Good thing I will not be driving under water (IMG:style_emoticons/default/blink.gif)
Sounds like I am the only one trying this stuff. It was easy to work with and inexpensive. I'll have the new carpet in by the weekend and will be able to report on the sound effects.
UPDATE: from driving with nothing but the seats and the dash to driving with "b-quiet", jute, carpet, and back pad is very nice. Now I need to get some window seals. They will only be rolled up in the winter, but that will also keep some cold out.
- Lo-Fi Version Time is now: 19th July 2025 - 05:51 AM
