> Brake light switch at pedal install question
rosenfe
post Jun 28 2014, 09:26 PM
On my 73 I've just rebuilt pedal cluster.question about switch activating arm .im not exactly sure if it sits behind or in front or the arm to master cylinder.looking for a picture
Replies(1 - 2)
Dave_Darling
post Jun 28 2014, 09:57 PM
914 Idiot
It sits on the "wrong" side. The obvious way to put it together is wrong. I believe that the washer on the pushrod pushes the switch until you press the pedal.
Give it a try; if the brake lights come on with the ignition switch on you have the switch on the wrong side of the washer. (IMG:style_emoticons/default/smile.gif)
--DD
rhodyguy
post Jul 2 2014, 11:20 AM
haynes. p.110, fig.8.4. don't forget to adj the piston rod free play.
- Lo-Fi Version Time is now: 4th March 2026 - 04:27 AM
