Flipping 3rd and 5th |
cwpeden |
Jun 29 2014, 11:45 AM
Great White North, huh? Group: Members Posts: 916 Joined: 20-August 06 From: Victoria BC Member No.: 6,693 Region Association: Canada |
I'm going to build an autcross trans out of my spares. I have one good trans with no shift/bearing problems a spare side shift and spare tailshift. Actually surprised it good considering how i drive it.
Just wonder what i need other than a seal kit? Its a stock 2.0L. |
Dave_Darling |
Jun 29 2014, 12:55 PM
The paper shims between the intermediate plate and the case. You will definitely need those.
Chances are at least so-so that you need one or both bearings in the intermediate plate. Once you're in the box, you may find a whole lot of things that need to be replaced. But you won't know until you get a look at them. --DD |
cwpeden |
Jun 29 2014, 01:13 PM
Thanks Dave,
Case is already open and everything is good. Now all i need are instructions. |
stugray |
Jun 29 2014, 01:37 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
The tool to remove the dogteeth gears.
Last time I tried to order it from PP, they were out of stock so think ahead. |
Bob L. |
Jun 29 2014, 03:45 PM
Senior Member Group: Members Posts: 848 Joined: 7-August 11 From: Austin TX Member No.: 13,411 Region Association: Southwest Region |
cwpeden |
Jun 29 2014, 03:46 PM
Would DrEvils video cover any of this? Swapping gears, that is.
stugray |
Jun 29 2014, 06:38 PM
Yes I highly recommend his video.
The teardown and rebuild would be the same, just parts in different places. |
Chris Pincetich |
Jun 29 2014, 10:29 PM
B-) Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
You have all the parts you need to swap gears (IMG:style_emoticons/default/beerchug.gif)
I did this 5 years ago, as well as swapped to a 12 lb flywheel. Fun for waking up more pep racing, and I still drive around w this transaxle all the time running errands and commuting. You'll need more gear oil to finish the job (IMG:style_emoticons/default/smile.gif) |
cwpeden |
Jun 29 2014, 10:59 PM
I just went to read the thread to buy the Dr's video and found that the question about swapping gears was only asked about 40 or 50 times. Good thing i started a new thread for it.
Thanks for the info guys. All this just to beat a frickin Miata at autocross in a stock 2.0(still wont happen). |
Lo-Fi Version | Time is now: 15th June 2024 - 11:41 AM |
