914 transmission, 914 transmission |
Jesper2803 |
Jul 7 2014, 12:27 PM
Newbie Group: Members Posts: 13 Joined: 7-July 14 From: Denmark Member No.: 17,595 Region Association: None |
Hello.. My 914 transmission is making an (whining) sound when im driving its apperes en all gears but its worst in fourt and fift... The gears shifts perfekt and i just poured ind new swepco oil.... Is this a bearing????
Thanks jesper. Denmark. |
stugray |
Jul 7 2014, 01:09 PM
Advanced Member Group: Members Posts: 3,825 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
An improperly set pinion depth is known for making that kind of noise.
Was the trans recently "rebuilt"? Has it always done it? Did it make the noise before you added the new oil? What weight oil did you use? |
Jesper2803 |
Jul 7 2014, 01:17 PM
An improperly set pinion depth is known for making that kind of noise. Was the trans recently "rebuilt"? Has it always done it? Did it make the noise before you added the new oil? What weight oil did you use? I used swepco 201. The noice was there before... And its eksaktly the same.. I hawe no info about a rebuild... And there is no signs it has been opened recently. How do i chek that pinion??? Thanks☺️ |
Jeffs9146 |
Jul 7 2014, 01:21 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
QUOTE Is this a bearing???? Thats what mine sounded like before I found this! Attached image(s) |
Jesper2803 |
Jul 7 2014, 01:29 PM
Ohhh f..k!!! Dit it mess up the intire gearbox??? What bearing is that? Pinion?
Jeffs9146 |
Jul 7 2014, 01:54 PM
Mike Bellis |
Jul 7 2014, 01:58 PM
Hello.. My 914 transmission is making an (whining) sound when im driving its apperes en all gears but its worst in fourt and fift... The gears shifts perfekt and i just poured ind new swepco oil.... Is this a bearing???? Thanks jesper. Denmark. (IMG:style_emoticons/default/welcome.png) |
Jesper2803 |
Jul 7 2014, 02:33 PM
Ohhh f..k!!! Dit it mess up the intire gearbox??? What bearing is that? Pinion? No it was just whining and it didn't fall appart until I removed the shaft from the intermediat plate! Ok.. Did the whining stop once you changed the bearing?? And is there any special tools needed to do the fix?? Jesper denmark. |
stugray |
Jul 7 2014, 02:41 PM
QUOTE And is there any special tools needed to do the fix?? Tool #1: http://www.914world.com/bbs2/index.php?act...=0#entry1402767 Other than that video, standard tools will get your tranny disassembled to the point where you replace the bearing. To reassemble you need the shift rod alignment tool from PP. But of course... "while you are in there"....... is another story :-) |
Jeffs9146 |
Jul 7 2014, 02:56 PM
Ohhh f..k!!! Dit it mess up the intire gearbox??? What bearing is that? Pinion? No it was just whining and it didn't fall appart until I removed the shaft from the intermediat plate! Ok.. Did the whining stop once you changed the bearing?? And is there any special tools needed to do the fix?? Jesper denmark. Yes my trans works great now! I replaced some syncros, and dog teeth while I was in there! All the parts were used but in good shape so it only cost me about $450! You should get the DrEvil Transmission Rebuild Video and decide if you can do it! It does require some special tools and knowledge and the "While your in there" should be considered! I did mine at the Dr's Clinic in Napa and have done a total of 3 so far with every one is still working very well! |
Jesper2803 |
Jul 8 2014, 01:19 AM
Ohhh f..k!!! Dit it mess up the intire gearbox??? What bearing is that? Pinion? No it was just whining and it didn't fall appart until I removed the shaft from the intermediat plate! Ok.. Did the whining stop once you changed the bearing?? And is there any special tools needed to do the fix?? Jesper denmark. Yes my trans works great now! I replaced some syncros, and dog teeth while I was in there! All the parts were used but in good shape so it only cost me about $450! You should get the DrEvil Transmission Rebuild Video and decide if you can do it! It does require some special tools and knowledge and the "While your in there" should be considered! I did mine at the Dr's Clinic in Napa and have done a total of 3 so far with every one is still working very well! Sounds great.. Where can i get that alignment tool??? |
bulitt |
Jul 8 2014, 03:59 AM
Achtzylinder Group: Members Posts: 4,188 Joined: 2-October 11 Member No.: 13,632 Region Association: South East States |
Whoa...Slow down a minute.
If it was me, before tearing down the trans, I would change that Swepco for a cheap ass Dino GL-5. No friction modifiers or additives. Can the wrong oil cause gear whining? Absolutely. http://www.914world.com/bbs2/index.php?sho...ansmission++oil |
Jesper2803 |
Jul 8 2014, 05:56 AM
Whoa...Slow down a minute. If it was me, before tearing down the trans, I would change that Swepco for a cheap ass Dino GL-5. No friction modifiers or additives. Can the wrong oil cause gear whining? Absolutely. http://www.914world.com/bbs2/index.php?sho...ansmission++oil It might be worth a try... But it shure sound like there is something wrong in that tranny... It sound a lot like the tranny in an old tracktor.. I really suspeckt a worn bearing... |
Jeffs9146 |
Jul 8 2014, 10:37 AM
Whoa...Slow down a minute. If it was me, before tearing down the trans, I would change that Swepco for a cheap ass Dino GL-5. No friction modifiers or additives. Can the wrong oil cause gear whining? Absolutely. http://www.914world.com/bbs2/index.php?sho...ansmission++oil It might be worth a try... But it shure sound like there is something wrong in that tranny... It sound a lot like the tranny in an old tracktor.. I really suspeckt a worn bearing... (IMG:style_emoticons/default/agree.gif) |
Jesper2803 |
Jul 8 2014, 10:54 AM
Jeffs9146 |
Jul 8 2014, 10:59 AM
No I agree with you that it is probably the bearing! (IMG:style_emoticons/default/beerchug.gif)
Dave_Darling |
Jul 8 2014, 11:38 AM
If you need new synchros, this tool is very handy:
http://www.pelicanparts.com/catalog/SuperC...pg11.htm#item46 Here's the alignment jig for the shift forks: http://www.pelicanparts.com/cgi-bin/ksearc...ber=TOL-721-T76 You may be able to get them cheaper elsewhere--international shipping may make a more local retailer a better deal, even if the list price is more. But it's worth asking what the shipping would be... Contact Glenn@pelicanparts.com and ask. (IMG:style_emoticons/default/smile.gif) --DD |
green914 |
Jul 8 2014, 11:43 AM
Senior Member Group: Members Posts: 1,467 Joined: 29-March 11 From: Sacramento, California Member No.: 12,874 Region Association: Northern California |
Jesper2803 |
Jul 9 2014, 06:09 AM
Jesper2803 |
Jul 9 2014, 09:23 AM
Ohhh f..k!!! Dit it mess up the intire gearbox??? What bearing is that? Pinion? No it was just whining and it didn't fall appart until I removed the shaft from the intermediat plate! Whats that bearing called??? Is this the one?? http://m.ebay.de/itm/291182474960?nav=SEARCH |
Lo-Fi Version | Time is now: 9th June 2024 - 09:17 PM |
