Sill cover cracks?, common issue? |
falcor75 |
Jul 16 2014, 03:09 AM
Senior Member Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia |
Both my sill covers have small crack from the underside and about an inch upwards about 10-12 inches in from the rear end, since both mine are cracked in the exakt same place I'm wondering if this is a common issue?
I'm going to drill a hole at the end of the crack and then weld them back up. Will probably weld up the jack holes to achieve a smooth look on the sill covers while I'm at it. (IMG:style_emoticons/default/welder.gif) |
GeorgeRud |
Jul 16 2014, 06:39 AM
Carefully check your longitudinals under the rocker panels to be sure they're not rusting.
falcor75 |
Jul 16 2014, 10:33 AM
SirAndy |
Jul 16 2014, 11:20 AM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Can you post a picture? I don't recall ever seeing a crack there ...
(IMG:style_emoticons/default/idea.gif) |
falcor75 |
Jul 16 2014, 11:54 AM
SirAndy |
Jul 16 2014, 12:32 PM
Aha, yes, i have seen this before. I would mount them first, make sure they align right with the rear of the fender and then weld them up. Shouldn't be a problem. (IMG:style_emoticons/default/smile.gif) |
914Sixer |
Jul 16 2014, 08:18 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Standard vibrational cracking of rocker panels. They crack where the long ends.
SirAndy |
Jul 16 2014, 08:47 PM
Standard vibrational cracking of rocker panels. They crack where the long ends. Might be a sign that you're missing the metal tabs inside your fender that are supposed to keep the lower portion of the rear fender from vibrating. (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 03:28 AM |
