> Where do you find these gaskets?
cary
post Jul 20 2014, 08:52 AM
I pulled the engine to replace the oil pump cover .... drip, drip, drip.
But this gasket came apart when I pulled the heater tin.
It goes inside heater tin that attaches to blower housing. #24. Keeps moisture from getting inside the heating system I assume.
Dug thru both AA and Pelican and found nothing. Made an attempt at Bus Depot but I have no idea what its called or the part number. I know that I replaced them around 7-8 years ago.
Replies(1 - 19)
injunmort
post Jul 20 2014, 09:26 AM
try 914rubber, vendor on this site
type47
post Jul 20 2014, 09:35 AM
Viermeister
I think what you're looking for is called a "branch piece gasket" by AA. From the PET 202-15, no figure number as it doesn't seem to appear in the figure,
021.256.325 A gasket for cover and
021.256.326 A "
here is the part in AA: skip this link
http://www.autoatlanta.com/results.php
if the link doesn't show the part, search the AA catalog for 021.256.325A (and don't search for 021.256.325 A, notice the space before the "A")
and the link above doesn't get to the part. Try
http://www.autoatlanta.com/porsche-parts/h...;section=202-15
and scroll down, the gaskets are in the parts list after 18 and (18) ...
see also:
http://www.914world.com/bbs2/index.php?showtopic=215402
barefoot
post Jul 20 2014, 09:55 AM
My tins are missing these gaskets. Rather than pay the big $$ from AA i plan on using hight temp silicone sealant to keep warm air leakage to a minimum. It also may help rattles away.
larryM
post Jul 20 2014, 09:34 PM
emoze
hardware store - std household door seals - glue 'em on with rtv
p.s. - the Parade concours judges will never know you don't have a 100 point car if you do this
bdstone914
post Jul 21 2014, 12:49 PM
bdstone914
QUOTE(larryM @ Jul 20 2014, 08:34 PM) *
Not sure how well a household seal will hold up to the heat.
Mike Blizzard was going to make them by 3d printing. I have a very old roll of asbestos paper that I am going to use to make some.
TeenerTech
post Jul 21 2014, 09:37 PM
some mechanic
I don't think the heat will be an issue considering that seal is on the cold side of the heat exchanger getting cool air blown over it at all times.
I removed all my heater boxes and parts right after a long drive and was able to grab a hold of it and not get burned!!!
cary
post Jul 21 2014, 10:38 PM
Here's the closest thing I've found.
http://www.mcmaster.com/#packing-seals/=sxxeq1
But we need 1/4 * 3/16, not 1/4 *1/4.
Bus Depot got back to me this afternoon. No go .....
rhodyguy
post Jul 22 2014, 08:14 AM
make an RTV bead where the gasket would lay on the branch piece sit and let it set up before installing. that way you're not 'glueing' them together. iirc the gasket from the 'other place' are fairly spendy.
saigon71
post Jul 23 2014, 06:34 AM
I made some with thick cork gasket material from FLAPS and glued them in with RTV. It worked well.
cary
post Sep 21 2014, 09:45 AM
Here's what I finally did. It's been curing since July. As you can see I only filled in the missed section. Should work.
Bartlett 914
post Sep 21 2014, 10:20 AM
I used an O-ring I had around. It sealed both top and bottom in one shot. Worked pretty good. You could also use o-ring cord stock and glue in place
pilothyer
post Sep 21 2014, 10:44 AM
I bought one of those red silicone flexible baking pans and cut out the seals and glued them in place with high temp silicone glue. they have always worked well and stayed in place even after a few "take off and put backs"
Mikey914
post Sep 21 2014, 10:52 AM
The rubber man
Pretty easy to make. And pretty cheap too. If you guys want me to make them I can in high temp silicone.
I'd guess about $2 a pop
bdstone914
post Sep 21 2014, 10:59 AM
bdstone914
QUOTE(Mikey914 @ Sep 21 2014, 09:52 AM) *
That would be great if you made them. You probably know the left and right sides are different sizes. I would take a few pairs.
Bruce
Larmo63
post Sep 21 2014, 01:07 PM
914s have heaters? (IMG:style_emoticons/default/blink.gif)
bandjoey
post Nov 18 2014, 03:15 PM
bandjoey
anyone making these? couldn't find them on 914rubber or anywhere else. if not i'll just layer gasket material and make them fit.
rhodyguy
post Nov 18 2014, 05:54 PM
What crap! $33.85 for one side and $38.54 for the other plus what ever they charge for 'handling' (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/unsure.gif) (IMG:style_emoticons/default/mad.gif) Oh mark....now I remember why I don't frequent the AA site
913B
post Nov 18 2014, 10:52 PM
I would be interested in a set.
mapguy
post Nov 18 2014, 11:30 PM
Freelance Generalist
I would also be interested in a set, provided I can get my grill badge by the time you pop them (IMG:style_emoticons/default/biggrin.gif)
(IMG:style_emoticons/default/poke.gif)
- Lo-Fi Version Time is now: 7th December 2025 - 07:21 AM
