Torsion bar Adj. ???? |
Mike Wofford |
May 31 2003, 11:07 AM
Member Group: Members Posts: 68 Joined: 29-April 03 From: Olympia, Wa. Member No.: 629 |
I have had my car up on jackstands doing a brake job and the exhaust. After lowering the car back down the drivers side of the car set up higher the the pass. I have rolled the car up and donw the driveway and the rear has evened out but the drivers front is still 1 1/2" higher than the passenger. any suggestions or tricks that would even the front back out.
Mike |
Bleyseng |
May 31 2003, 11:18 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Did you adjust the tbars?
Do you have adjustable rear spring perches? maybe a clip slipped. You can look to see if a rear spring is stuck or out of the register the spring fits into. If it isn't in the correct spot the spring sits wrong and the car is then tillted. Geoff |
Mike Wofford |
May 31 2003, 11:25 AM
No I have not adj. the tbars. I have checked the rear springs and they seem to be in the correct position, I dont have adj. spring perches. Before I lifted the car it sat even.
Mike |
Bleyseng |
May 31 2003, 11:38 AM
A rear spring must be hanging up or out of register in the perches.
Check them! |
seanery |
May 31 2003, 11:49 AM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
If the car runs, drive it a couple miles...it should settle back down.
I've noticed this on my cars coming off the lift. |
rhodyguy |
May 31 2003, 01:46 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
mike, after doing the work you have, just rolling it back and forth prob won't do the job. tab it out or get a 3 day trip ticket, drive it up to my place, and we'll see what we can figure out on the level cement floor in the garage.
kevin |
Lawrence |
Jun 2 2003, 09:32 AM
Senior Member Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None |
This has happened to my cars in the past - usually a spirited drive to go get some chili dogs and ice cream fixes it.
If it doesn't fix it - well, I feel better about life anyways. (IMG:style_emoticons/default/smile.gif) -Rusty |
Lo-Fi Version | Time is now: 12th June 2024 - 08:22 AM |
