Stumped Again - Rear Targa Pad Removal |
CptTripps |
Jan 22 2005, 09:45 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
I've got a sneaking suspission that something is not right with my rear targa pad. I've removed every screw I can find, and it's catching on SOMETHING. Is there a trick to it's removal? Should I take the latches out first?
markb |
Jan 22 2005, 09:47 AM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
You've removed the side pieces, right? Other than that, your guess is as good as mine. (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
jim912928 |
Jan 22 2005, 09:56 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
hmmm...i had mine out this summer and don't remember. But, make sure the sides ones are off first, then take out all screws (there are some on the front and some going in from the bottom). There might be some "hooks" like the backpad had (I know there were on my 911 targa...that was a pain and the one I remember). Pull it forward and not down if this is the case. I never took my latches off so that is not the issue.
Jeffs9146 |
Jan 22 2005, 10:09 AM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
You take it out in one piece!
Remove the seatbelts and push up on the pad! There are clips that hold the pad in along the top! You need to push up to release the clips! Jeff |
jim912928 |
Jan 22 2005, 10:17 AM
Jeff..I believe he's talking about the rear targa bar pad...not the back pad
Jeffs9146 |
Jan 22 2005, 10:19 AM
Oh...My Bad!! (IMG:http://www.914world.com/bbs2/html/emoticons/alfred.gif)
Jeffs9146 |
Jan 22 2005, 10:20 AM
rhodyguy |
Jan 22 2005, 10:33 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,093 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
unhook the springs. they are independent of the pad.
k |
double-a |
Jan 22 2005, 11:13 AM
Senior Member Group: Members Posts: 987 Joined: 15-September 03 From: vancouver, wa, usa Member No.: 1,162 Region Association: Pacific Northwest |
i did this last night in fact. i found that many of the screws "feel" like they're out, but are still partially threaded. make sure the're all out and it should come off. the underside screws are easy to remove altogether, and that's probably a good idea. the front screws are more difficult, they're a pain to locate in the first place and sometimes it's hard to tell if they're completely loosened or not.
if you're sure you have all the screws out, you may be catching on the latches a bit. it'll work. ~a |
vortrex |
Jan 22 2005, 11:43 AM
Senior Member Group: Members Posts: 1,687 Joined: 24-December 02 From: SF, CA Member No.: 4 Region Association: None |
yup, the screws are really buried on that thing.
Jeffs9146 |
Jan 22 2005, 02:06 PM
OK, I pulled out my old pad and there are 12 Screws and it looks like the unit slides out twards the front not down. The latch handles will get in the way but you sould be able to work around them. I loosened my latches and then removed everything.
I can post a photo of the piece removed if you would like!? Jeff |
CptTripps |
Jan 22 2005, 05:34 PM
Thanks! That would help a ton. I've got just about every other piece out of the interior...I'm not sure why this one is giving me such a hard time! |
double-a |
Jan 22 2005, 06:35 PM
don't feel bad, it's a royal pain to get out. took me quite a long time the first time i tried. ~a |
Jeffs9146 |
Jan 22 2005, 08:10 PM
Sorry, I left the house before you responded. I will shoot a photo tomorow when I get back to Discovery Bay tomorow. Jeff |
CptTripps |
Jan 26 2005, 07:12 AM
Ever get that photo? It's still the only piece of the interior intact. =)
I won't be doing anything to the pain for ne next couple of days. I've got to replace the floor pans, so that'll take my weekend. Whenever... |
Jeffs9146 |
Jan 26 2005, 04:59 PM
Sorry, I never made it back to my house. I ended up going to Tahoe and skiing!
Here are a few photos. If you need larger ones let me know and I will e-mail them to you!! Jeff Attached image(s) |
Jeffs9146 |
#2
Attached image(s) |
Jeffs9146 |
Jan 26 2005, 05:00 PM
#3
Attached image(s) |
Jeffs9146 |
#4
Attached image(s) |
Jeffs9146 |
Jan 26 2005, 05:01 PM
#5
Attached image(s) |
Lo-Fi Version | Time is now: 10th June 2024 - 12:31 PM |
