Dellorto Carbs, How to sync and get the most out of them. |
kixx |
Jul 28 2014, 11:31 AM
Newbie Group: Members Posts: 11 Joined: 6-July 11 From: AR Member No.: 13,283 Region Association: None |
Hello All, I have worked on carbs before but have never had to sync them, I have looked on here and have not found the sync ing carbs for dummies guide yet. I am at a loss on where to find info for the dell carbs to get started. The car does start and run as well as idles fair, really seems to just bottom out (lacks power) when i try to get it up to speed. Any and all help is very much appreciated, also i will be needing a temp sensor and a set of air filters for them, any good shop references ??? Thanks, Best Regards
ConeDodger |
Jul 28 2014, 12:31 PM
Apex killer! Group: Members Posts: 23,610 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
I would start with the linkage. The common hex bar variety makes synching an exercize in frustration. Original Customs had a group buy on a very good system. Mark always buys more for the shelf so you could start there.
yeahmag |
Jul 28 2014, 05:44 PM
Advanced Member Group: Members Posts: 2,422 Joined: 18-April 05 From: Pasadena, CA Member No.: 3,946 Region Association: Southern California |
CB Performance makes a guide that will walk you through the ins and outs of dellorto's. It's a great starting point. They should also have all the parts you need to get it going from a dell stand point.
The temp sensor (assuming oil) can be had from many Porsche retailers: Pelican Parts, Sierra Madre Collections, etc... If you post your specifics about the carbs we can tell you if you are close: Air Correction Jet Venturi Main Jet Idle Jet That's the bare minimum you need and to just get it going. A very basic setup would look like this: Air Correction = 180 Main Jet = 4 * Venturi (stamped on the inner part of the venturi) 60 idle A good chunk of the time not only will that run, but it will be right. |
PotterPorsche |
Jul 28 2014, 07:59 PM
Member Group: Members Posts: 295 Joined: 10-November 13 From: Hayward CA Member No.: 16,628 Region Association: None |
Start here:
http://www.aircooled.net/vw-carburetor-tech/ And I love dellortos . I have 36's ,40's and 45's. I sold a set back in 2000 for $275 spent the last couple years Searching swaps. Also check out blackline racing they have a lot of carb parts. http://www.blacklineracing.net/about.html Couple things: Jet doctors work great on dellortos clogged idles almost non existent. You need 2 sets http://vwparts.aircooled.net/Dellorto-DRLA...8-p/cb-7348.htm You also want to buy a squirrel cage to balance the carbs. http://vwparts.aircooled.net/Snail-Type-Sy...te-sk-china.htm And lastly you may want to rent an lm2 wideband from www.aircooled.net to tune those babies perfect. |
kixx |
Aug 5 2014, 03:11 PM
Thank you all very much, I will post specific on the vehicles I have. I now have two 914's one i will be parting out and letting go of one of them, while completing the other. One is a 1975, and the other is a 1971. I will compile a list of each, and hope to let go of parts that will help others out as well. A friend has loaned me a syncro, (motosync) I have not had good results as of yet. I will get pics and specifics loaded on here soon..
anderssj |
Aug 5 2014, 05:07 PM
Dog is my copilot... Group: Members Posts: 1,663 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
PM sent.
rhodyguy |
Aug 5 2014, 05:20 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
first thing i want to know is what sort of fuel pump do you have on your car? a square thing that rattles or round one that goes 'whirr' when you turn your key to the first position?
second is what size of an engine is in your car? |
Eric_Shea |
Aug 5 2014, 05:24 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
This site is also good:
www.performanceoriented.com |
kixx |
Aug 6 2014, 02:18 PM
These are on the 71 (the one i am going with unless a real good reason to build the 75 comes up) The other has weber one barrels. 2.0 liter fresh overhaul, many new parts and time has been put into this car and for the most part has to this point been done well. This is the fuel pump being used.
Attached thumbnail(s) |
kixx |
Aug 6 2014, 02:19 PM
Fuel pump
rhodyguy |
Aug 6 2014, 02:27 PM
where's the pump picture? you need to ditch the 'old school' fuel line, ALL of it, for modern fuel line and get at least one shouldered fuel line clamp. your linkage has prob seen better days. i can't make out the DRLA # in the picture. use some pbblaster on the carb fasteners and linkage connection points before you start wrenching on them.
yeahmag |
Aug 6 2014, 02:32 PM
Looks like you may have a vacuum port uncapped too. Mine don't have that (40's), so I'm not sure if you can close it off just by turning it (like a brake bleeder) of if you need to cap it.
kixx |
Aug 6 2014, 02:44 PM
this is how i got the car, i have not done much, mostly research. here are a few more pics
hey is there a place on here to post several pics, can members create galleries ? Attached thumbnail(s) |
kixx |
Aug 6 2014, 02:45 PM
Looks like you may have a vacuum port uncapped too. Mine don't have that (40's), so I'm not sure if you can close it off just by turning it (like a brake bleeder) of if you need to cap it. does the other side look like the vacuum is broke off or the stem missing?? |
yeahmag |
Aug 6 2014, 02:47 PM
You may want to sell those. I ran 45's on a full tilt drag motor (VW). They will never behave the way you want unless that is a large displacement, huge cam, high rev motor. You'll get enough for them to buy yourself a set of 36's or 40's and then some.
kixx |
Aug 6 2014, 02:49 PM
where's the pump picture? you need to ditch the 'old school' fuel line, ALL of it, for modern fuel line and get at least one shouldered fuel line clamp. your linkage has prob seen better days. i can't make out the DRLA # in the picture. use some pbblaster on the carb fasteners and linkage connection points before you start wrenching on them. looks like 45s, you know about them? pbblaster ??(penetrate oil) |
kixx |
Aug 6 2014, 02:51 PM
You may want to sell those. I ran 45's on a full tilt drag motor (VW). They will never behave the way you want unless that is a large displacement, huge cam, high rev motor. You'll get enough for them to buy yourself a set of 36's or 40's and then some. i have a set of weber 1 barrels on the 75 Attached thumbnail(s) |
ThePaintedMan |
Advanced Member Group: Members Posts: 3,886 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Good spot Aaron. They should both have a vacuum nipple, unless someone inserted a brass plug at some point that we can't see. Either way both need to be capped otherwise synching/tuning will be an effort in futility.
This will be something that you'll look for later on (after everything is synched) but keep an eye out for the dreaded Dellorto drip. Not necessary for us to explain here, but the 45s are particularly susceptible to this condition. First things first is following the advice already posted though. Good luck! |
kixx |
Aug 6 2014, 02:56 PM
Good spot Aaron. They should both have a vacuum nipple, unless someone inserted a brass plug at some point that we can't see. Either way both need to be capped otherwise synching/tuning will be an effort in futility. This will be something that you'll look for later on (after everything is synched) but keep an eye out for the dreaded Dellorto drip. Not necessary for us to explain here, but the 45s are particularly susceptible to this condition. First things first is following the advice already posted though. Good luck! are the air/fuel screws have spings on them? these seen loose, like they could vibrate loose, what you think?? keep the 45s or go with the webbers |
yeahmag |
Aug 6 2014, 03:00 PM
Single barrels aren't going to help you much. You can get the 45's running and then see how you feel. Reversion is worse on a dual, single barrel setup than the dual/dual setup you have now. I'd get it running and see how you feel.
The idle mixture screws have a spring on the inside to help with shake. |
Lo-Fi Version | Time is now: 6th June 2024 - 05:48 AM |
