warped door panale fix |
wes |
Jul 31 2014, 03:44 PM
wes Group: Members Posts: 1,589 Joined: 8-December 07 From: Ukiah Ca Member No.: 8,436 Region Association: Northern California |
wes |
Jul 31 2014, 06:16 PM
Wow, I must be the only one!
rgalla9146 |
Jul 31 2014, 06:50 PM
Advanced Member Group: Members Posts: 4,561 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
Yes, I've done what you suggest on Isetta interior panels.
Those were pretty thin cardboard , much thinner than 914 door panels but I got decent results. Not perfect but better than they were. I'd suggest liberal water, two large flat surfaces to make a sandwich and weights to apply pressure. Put the whole package in the sun to promote drying. If possible use a perforated metal panel on the board side to allow evaporation. |
wes |
Jul 31 2014, 07:22 PM
Thanks just need to here from another as mine is only on the drivers side and not to bad, also right in the area of a missing clip so I'm thinking with the new clip hopefully it will be ok.hopefully
johannes |
Aug 1 2014, 05:36 AM
Club Porsche 914 France President Group: Members Posts: 3,084 Joined: 13-January 06 From: France Member No.: 5,409 Region Association: France |
I used steam iron.
914GT |
Aug 1 2014, 10:13 AM
Senior Member Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region |
I've also used the steam iron as Johannes did, followed by letting them sit with weights on top overnight until completely dry. When flat and straight I apply a couple coats to both sides (vinyl removed) with waterbased clear polyurethane. This helps waterproof them so they don't warp again.
Lo-Fi Version | Time is now: 1st June 2024 - 06:03 AM |
