Idling problems, Car dying out after warmed up |
911 defector |
Jul 31 2014, 05:26 PM
Newbie Group: Members Posts: 16 Joined: 17-December 11 From: Chicago Member No.: 13,904 Region Association: Upper MidWest |
I am having a problem with my '73 914 2.0. The car starts and drives fine until it is warmed up. One it gets warm the car will not idle properly. The RPM's go down to 100 or 200 and the car will eventually die out. If I turn it off, it will reluctantly start, but I have to keep the RPM's up or it dies. The car has the fuel pump in the front, I changed the head temp sensor that monitors the fuel injection. The car will run and drive fine as long as I keep the RPM's up.
Also, If I push down hard on the spark plug wire lead for cylinder #4 (passengers side of engine in the front) on the distributor cap, the idle goes back up. I checked all the wire on the spark plugs and on the distributor cap and they are firmly attached, as is the distributor cap as well. Any suggestions would be greatly appreciated. Thanks, Jon |
ripper911 |
Jul 31 2014, 05:48 PM
corde pulsum tangite Group: Members Posts: 2,920 Joined: 25-April 10 From: Powder Springs, GA Member No.: 11,654 Region Association: South East States |
Keep the side of your foot on the accelerator pedal to keep the engine from dying.
Jeffs9146 |
Jul 31 2014, 05:56 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
CHTS
Reno914 |
Jul 31 2014, 06:15 PM
Newbie Group: Members Posts: 31 Joined: 18-August 09 From: Reno Member No.: 10,694 Region Association: Northern California |
Have you checked the vacuum line to the manifold pressure sensor, or the sensor itself for the fuel injection?
Reno |
Java2570 |
Jul 31 2014, 07:10 PM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
When you first start up your engine, what is your RPM at? Is your AAR valve working correctly? You likely should check all the basics out and be methodical in how you proceed.
A must have D Jet resource: http://members.rennlist.com/pbanders/djetparts.htm |
TheCabinetmaker |
Jul 31 2014, 09:14 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
When it first starts and idles fine turn the air bypass screw open till it idles around 1500 rpm. Then when it's warm and the idle drops readjust it to about 1000 rpms. You should also check dwell and timing. Have you checked adjustment on the tps?
911 defector |
Aug 1 2014, 12:25 PM
Changed head temp sensor (for fuel injection located by #3 cylinder), warmed up car, then adjusted air bleeder screw at idle. Backed screw out all the way and RPM's are still a little below 900, and car runs very rough. Thanks for suggestions!!
Lo-Fi Version | Time is now: 5th June 2024 - 12:24 AM |
