OT: Needing a big favor, I need to borrow a set of webbers and manifold! |
Dr Evil |
Aug 2 2014, 07:41 AM
Send me your transmission! Group: Members Posts: 23,002 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
I am starting this post as not all of you follow the copious Bus thread (link in my sig below).
I have been developing a CIS based system for the 3.1L corvair engine in it. It worked well enough to do a large circle route around Lake Ontario....but then it started messing up and has sat for months now. I am moving and dont want to tow it and would love to use it to actually haul stuff (shocker). So, it is time to switch to dependable and easier - Webber 3C or Zenith carbs. What I need is a set of carbs big enough to feed a 3.1 with mild cams, and the manifolds as I do not have any of this. I am not looking to buy as I am trying to same my $$$ to prove I have enough to the mortgage people to secure my loan. However, if I have to buy I have to buy and I will make do. But, I thought I would as here first. I can trade labor (IMG:style_emoticons/default/wink.gif) Thanks for your consideration. |
Dr Evil |
Aug 2 2014, 07:42 AM
Oh ya, I am partially carb stupid so recommendations for size, or other important parameters is welcome (IMG:style_emoticons/default/smile.gif)
Dr Evil |
Aug 2 2014, 11:40 AM
If I were to buy a set, if it comes to that, what size would I be looking for? I see some Zenith cores and NOS ones on ebay. No idea if they would work. Also, dont the Weber and Zeniths use different manifolds? I would hate to go back to the 4bbl Holley as I sold all of my major pieces. I do have a special manifold to fit the heads.....(IMG:style_emoticons/default/idea.gif)
billh1963 |
Aug 2 2014, 07:09 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
Starr Cooke is the man for corvair carbs. He sells on eBay and you can probably google him as well. He might be a good resource to see what options you have.
r_towle |
Aug 2 2014, 07:49 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
I think it might be easier for you to get someone to give you a 911 six cylinder motor and put in something people actually understand.....
scotty b |
Aug 2 2014, 07:57 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
I think it might be easier for you to get someone to give you a 911 six cylinder motor and put in something people actually understand..... (IMG:style_emoticons/default/popcorn[1].gif) |
Dr Evil |
Aug 2 2014, 10:22 PM
Starr Cooke is the man for corvair carbs. He sells on eBay and you can probably google him as well. He might be a good resource to see what options you have. Well aware of him. He is located in my home town and is the guy that did my heads. I am planing on going with a 2bbl Holley 350 per the recommendations from the Corvair forum. Cheap and easy and should get the bus to OH under its own power. As for webers, I will likely go PMO if I go that way. Might as well spend for a system that is better and works without a lot of dicking around. Who knows, I may like the 2bbl. |
Dr Evil |
Aug 2 2014, 10:24 PM
Lo-Fi Version | Time is now: 1st June 2024 - 03:34 AM |
