Slooooow Wipers, Checked ground. Bad motor field ? |
914Sixer |
Aug 2 2014, 06:15 PM
914 Guru Group: Members Posts: 8,897 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I checked the wiring to see if everything was good and it appears to be. Wipers start out slow and gain a little speed but not much. High speed is just barely working. Nothing seems to be binding underneath. Not excited about pulling gas tank and air box.
saigon71 |
Aug 2 2014, 07:48 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
It may be your motor, but before pulling the tank & air box to replace it, drop your fuse block underneath the dash. Pull the relays out and clean the connections. Take a small screwdriver between the prongs and bend them out slightly so they make better contact and test your wipers again.
I had intermittent problems with my wipers, then read a thread on 914world with this suggestion. It fixed everything. (IMG:style_emoticons/default/beerchug.gif) |
r_towle |
Aug 2 2014, 07:50 PM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Clean and greased 40 year old wiper linkage also helps.
Rand |
Aug 3 2014, 02:54 AM
Two kinds of lube. One on your moving parts. The other on the glass, ala RainX. Amazingly, the right use of RainX and you don't want wipers.
GaroldShaffer |
Aug 3 2014, 12:13 PM
You bought another 914? Group: Benefactors Posts: 7,623 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Clean and greased 40 year old wiper linkage also helps. (IMG:style_emoticons/default/agree.gif) that and pull the arms off (and chrome cape & nut) add a few drops of oil to the arm shafts. |
partsman |
Aug 3 2014, 06:58 PM
forever hooked Group: Members Posts: 276 Joined: 27-February 04 From: Bradford, MA Member No.: 1,726 Region Association: North East States |
I recently replaced my switch and there was a noticeable increase in speed....just thought I'd mention it
Cap'n Krusty |
Aug 3 2014, 08:14 PM
Remove the arms and the circlips that hold the shafts in position. Lube the shafts with a good quality penetrating oil. Run the wipers. Put nuts on the shafts to prevent mushrooming. More than one nut may be prudent, if they'll fit. Gently tap on the shafts, knocking them downward into the threaded housings. Keep lubing them until they move freely. When they're loose, shut off the wipers, pull the shafts back out, and reinstall the circlips.
The Cap'n |
914Sixer |
Aug 3 2014, 09:24 PM
I got a round to the wipers today. I did pull the arms and let the wiper run with out them. No noticeable difference. A new problem cropped up when I put the arms back on. They stop about the 3/4 position. I reset the switch and mounted the arms again. They the wipers went below the windshield. Kept moving the arms to different positions with similar results. I will do as the Cap'n says and lube the shafts with PB Blaster tomorrow. As an added bonus I found that one of the ears on the fuse block was broken off. So there is an another job to add to the list. Probably going to get a JWest block and be done with it. (IMG:style_emoticons/default/headbang.gif)
Lo-Fi Version | Time is now: 1st June 2024 - 12:34 PM |
