i have painted pedrini rims,need to get paint off |
rosenfe |
Aug 3 2014, 07:37 PM
Senior Member Group: Members Posts: 561 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
they came painted to match cheap body paint,currently magenta red.is this a big job for auto shop to remove pain and restore to roiginal silver or whatever was standard with car?.car is a 73 .
Cuda911 |
Aug 3 2014, 08:00 PM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
You can do it yourself. Figure an hour per wheel to strip.
I started the stripping with some aircraft coating stripper... worked great but ran out before I was done and didn't feel like going to the store. Finished with regular old Jasco paint stripper. A bit slower, but still worked well. Then> wet sanded > primed > sanded again > painted > sanded > painted. If you take it to a shop, they will probably just bead blast it, way faster than my hand-stripping. You might want to just take them to a powder-coater. Prolly $100 or so per wheel to strip and powder coat. A few before, during, after pix: Attached image(s) |
rosenfe |
Aug 3 2014, 08:43 PM
You can do it yourself. Figure an hour per wheel to strip. I started the stripping with some aircraft coating stripper... worked great but ran out before I was done and didn't feel like going to the store. Finished with regular old Jasco paint stripper. A bit slower, but still worked well. Then> wet sanded > primed > sanded again > painted > sanded > painted. If you take it to a shop, they will probably just bead blast it, way faster than my hand-stripping. You might want to just take them to a powder-coater. Prolly $100 or so per wheel to strip and powder coat. A few before, during, after pix: What is the final color called |
Cuda911 |
Aug 3 2014, 08:57 PM
I used Duplicolor Automotive Primer/sealer, followed by Duplicolor automotive Stainless Steel. Came out great!
Lo-Fi Version | Time is now: 7th June 2024 - 07:15 PM |
