Still working in electrical gremlins, No High Beam indicator light |
914Sixer |
Aug 5 2014, 09:01 PM
914 Guru Group: Members Posts: 8,900 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I got all the dash lights working except the high beam indicator light. Swapped it out the the turn signal light indicator bulb. Bulb and holder are good. I did not think to put a meter on it and flash the turn signal switch from low to high. Duh ! I did swap the headlight relay out with another good working one and got the same result. I am thinking the new TS switch is not sending the signal to the light, however it does flash from low to high beams. Defective wiring in switch or bad wiring in plug harness ?
Adding this to the continuing list of little @##$$%@. (IMG:style_emoticons/default/dry.gif) |
Mike Bellis |
Aug 5 2014, 10:09 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
The high beam indicator gets power from one of the high beam fuses. If the high beams work, you should have power on the wire, when the lights are on.
The wire is only about 1 foot long or so and easy to trace. |
Hank914 |
Aug 6 2014, 05:47 AM
Member Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
I was wondering about that hi beam light also. Mine works, but very very dimly. Do the bulbs slowly fade out or just die? The green bulb in the speedo us super bright, but not the hi beam blue.
timothy_nd28 |
Aug 6 2014, 06:57 AM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
Make sure the gauge cans are grounded
lsintampa |
May 8 2016, 11:37 AM
Senior Member Group: Members Posts: 520 Joined: 28-January 13 From: Tampa, FL Member No.: 15,441 Region Association: South East States |
I know this is an old thread.... but I found it because I had the same issue.
In my case the issue was simply that you can't see that blue light in daylight. Since you can't see it inside the can, the only way is to set high beams on in a dark place. It most likely was / is just fine. (IMG:style_emoticons/default/beer.gif) |
914werke |
Oct 3 2018, 06:16 PM
"I got blisters on me fingers" Group: Members Posts: 10,120 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
Resurrection, So troubleshooting inop driving lights it dawns on me that they should only work if on low beams, so I flip the stalk and sure enough they were on High the whole time...DOH!
Problem is the High beam indicator isn't working ...as it should~ Pull the gauge and check the bulbs & grounding ...all good. Hmmm (IMG:style_emoticons/default/idea.gif) |
Rob-O |
Oct 3 2018, 08:53 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
As stated above, the small lens inside the gauge ends up aging to a non-transparent black color over time. Used to be blue back when new. I changed mine using the plastic tabs from ‘hanging file folders’ that I picked up at Staples. I used the red for the low fuel light (because those are all a weird whitish red color now). Yellow for turn signals and green for running lights and blue for high beams. Some of the pieces I doubled up the thickness. For instance on the fuel lamp I put two pieces of red in the gauge. Just one piece looked okay from the outside but when the light came on indicating low fuel it looked pink.
adolimpio |
Oct 4 2018, 04:00 AM
Art Group: Members Posts: 182 Joined: 10-March 10 From: Greenwood SC Member No.: 11,449 Region Association: South East States |
As stated above, the small lens inside the gauge ends up aging to a non-transparent black color over time. Used to be blue back when new. I changed mine using the plastic tabs from ‘hanging file folders’ that I picked up at Staples. I used the red for the low fuel light (because those are all a weird whitish red color now). Yellow for turn signals and green for running lights and blue for high beams. Some of the pieces I doubled up the thickness. For instance on the fuel lamp I put two pieces of red in the gauge. Just one piece looked okay from the outside but when the light came on indicating low fuel it looked pink. I had the same problem. Lamp was ok, but lense had become opaque over time. |
DRPHIL914 |
Oct 4 2018, 06:52 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
interesting as mine has never worked since I bought the car but this may be why! , getting ready to swap out my gauges with Tim's LED set I have soon so I will find out soon enough if its wiring or not.
sometimes these resurrected threads are very timely! |
Lo-Fi Version | Time is now: 3rd June 2024 - 07:51 AM |
