Oil Temp Sender Torque? |
A&P Mech |
Aug 9 2014, 10:08 AM
Member Group: Members Posts: 401 Joined: 10-September 13 From: United States Member No.: 16,371 Region Association: Rocky Mountains |
I am replacing the o-ring and gasket on my taco plate. I have a 74 2.0L and I am having a tuff time finding the required torque value for the oil temp sender. Can anyone tell me what the sender needs to be torqued to? The only info I have found on the taco plate installation is the torque value for the two 6mm bolts that hold the plate to the case. I read that they need to be torqued to 9 ft/lbs, does that sound correct?
Thanks for the help! Ray |
rnellums |
Aug 9 2014, 02:18 PM
Professional Enthusiast Group: Members Posts: 1,646 Joined: 26-November 09 From: Littleton, CO Member No.: 11,072 Region Association: Rocky Mountains |
If i remember correctly it just tight enough so it doesn't leak (IMG:style_emoticons/default/shades.gif) . BTW, i'll be swinging by in a bit to drop off a spare throw out bearing.
TheCabinetmaker |
Aug 9 2014, 02:40 PM
I drive my car everyday Group: Members Posts: 8,301 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I'm not where I can access my list, but 6lbs it's coming to mind.
TheCabinetmaker |
Aug 9 2014, 02:41 PM
A&P Mech |
Aug 9 2014, 03:00 PM
If i remember correctly it just tight enough so it doesn't leak (IMG:style_emoticons/default/shades.gif) . BTW, i'll be swinging by in a bit to drop off a spare throw out bearing. Sounds great, come on over. Thanks Ross! I'm not where I can access my list, but 6lbs it's coming to mind. Thanks for the Help. I went with 6lbs. Ray |
Lo-Fi Version | Time is now: 4th June 2024 - 04:13 PM |
