| Larmo63 |
Aug 9 2014, 03:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,267 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I know the cars come pre-wired, I now have stock fogs installed on my '73 1.7L, and have a few questions. Should the wires on the front be wired all the way into to foglight bodies? What the factory left is still there, including the rubber grommets so do they wire right through, or should I make connections with the wires coming out of my lights? (does that make sense?) Are all of the correct wires just ready for plug in above the fuse box? My car hasn't been fiddled with, so I have no doubt they will still be there. I bought the bypass wiring kit on eBay so that the fogs will work on the flasher and independently of the headlight switch. Anybody here have comments on that mod? Thanks ahead of time! (IMG:style_emoticons/default/confused24.gif)
| SirAndy |
Aug 9 2014, 03:13 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Lets start with the obvious, what year is your car?
Some of the early cars did *not* have the fog light wiring.... Besides that, if you have the wires they're all there. All you need is a switch on your dashboard, connect the wires and you're good to go. (IMG:style_emoticons/default/smile.gif) PS: Not sure if the fogs use a relay, my memory on that is a bit foggy (IMG:style_emoticons/default/biggrin.gif) But if they do you might have to add one to your fuse-board. |
| Black22 |
Aug 9 2014, 03:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 1-November 07 From: Creswell, OR Member No.: 8,290 Region Association: Pacific Northwest |
I know the cars come pre-wired, I now have stock fogs installed, and have a few questions. Should the wires on the front be wired all the way into to foglight bodies? What the factory left is still there, including the rubber grommets so do they wire right through, or should I make connections with the wires coming out of my lights? (does that make sense?) Are all of the correct wires just ready for plug in above the fuse box? My car hasn't been fiddled with, so I have no doubt they will still be there. I bought the bypass wiring kit on eBay so that the fogs will work on the flasher and independently of the headlight switch. Anybody here have comments on that mod? Thanks ahead of time! (IMG:style_emoticons/default/confused24.gif) My 74 didn't come with fogs, but I added the Pilot driving lights. All the wiring was tucked in the front trunk. Just added quick spade connectors to my lights and plugged them in. Also added a fog light switch to the dash and did the trick with the headlight switch that allows me to run them without the headlights being on (search for help on that). I hate electrical work and it was not difficult at all. |
| Larmo63 |
Aug 9 2014, 03:18 PM
Delete.
| DRPHIL914 |
Aug 9 2014, 05:10 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,907 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
My 75 had the wiring already in the trunk, but the car originally was ordered with the appearance group and should have hadthem in place but one of the previous owners took them out! They havve since been replaced. If memory serves me correctly its in the haynes manual .
| Porschef |
Aug 9 2014, 05:16 PM
How you doin' ![]() ![]() ![]() ![]() Group: Members Posts: 2,180 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States
I added fogs along with the bumper backdate on my 76; the wiring was already there behind the dash and in the front of the trunk. A nice addition to the fogs is a JWest fog kit; it allows the fogs to be used as flashers when the headlights are off, and allows use of fogs separate from the headlights. $25 clams well spent.
| Black22 |
Aug 9 2014, 06:58 PM
Sorry, the car is a '73 and I do have the switch installed already. Is there a thread on this? Is there a thread on the modification? Here ya go. http://www.914world.com/bbs2/index.php?sho...og+light+wiring |
| toolguy |
Aug 9 2014, 07:22 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California
Keep in mind, if you use factory wiring, Fog lights will only come on when the low beams are on. .
Much simpler to make your own wiring plan, and rewire everything to use the whenever the parking lights are on. . involves moving a lead on the headlight switch. . |
| Hank914 |
Aug 9 2014, 11:29 PM
Member ![]() ![]() Group: Members Posts: 389 Joined: 7-April 14 From: CA and OR Member No.: 17,215 Region Association: None |
Keep in mind, if you use factory wiring, Fog lights will only come on when the low beams are on. . Much simpler to make your own wiring plan, and rewire everything to use the whenever the parking lights are on. . involves moving a lead on the headlight switch. . Question: My fog lights can be on when the low beams are on, and go off when I hit the hi beams, just as you say above. My question is: do you have to have the head lights on (low beams or parking lights) or can you run fog lights without he head light switch being on? Thanks. I've got a 1972 1.7. |
| smveril |
Aug 10 2014, 06:42 AM
Mikey ![]() ![]() Group: Members Posts: 50 Joined: 6-December 04 From: Cincinnati, OH Member No.: 3,232 Region Association: Upper MidWest |
I am reinstalling my driving lights on my 73.
There is a rubber grommet in the light case for the wire. You do need to take the front off to plug in the wires. There is also a grommet on the body for the horn and driving lights |
| Larmo63 |
Aug 10 2014, 03:27 PM
1973 914: What wires am I looking for coming out of the wiring harness under the dash and where/what do they hook up to? The front wiring was pretty straightforward and obvious.
Wire colors? Wire locations? I don't have the extra mod yet , but I'd to have the fogs come on by the foglight switch only for now. Sorry for all the silly questions. Before I tear into it, I'd like this to be clear. I'm printing out the wiring diagram as we speak, but any help, helps! |
| SirAndy |
Aug 10 2014, 04:11 PM
Haynes manual or for color diagrams, go here:
http://www.pelicanparts.com/914/914_electrical_diagrams.htm (IMG:style_emoticons/default/smash.gif) |
| Larmo63 |
Aug 10 2014, 04:34 PM
Delete.
| worn |
Aug 10 2014, 04:51 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,560 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
1973 914: What wires am I looking for coming out of the wiring harness under the dash and where/what do they hook up to? The front wiring was pretty straightforward and obvious. Wire colors? Wire locations? I don't have the extra mod yet , but I'd to have the fogs come on by the foglight switch only for now. Sorry for all the silly questions. Before I tear into it, I'd like this to be clear. I'm printing out the wiring diagram as we speak, but any help, helps! In my '76 I found the appropriate colored wires and a hole for the switch under the dash. I just plugged them into the switch. Up front I goofed and accidentally wired my new lights to wiring provided for an optional second horn. But then I found the correct wires, and again no crimps, just plug. I did have to cut into the rubber bumper to mount the lights though. I also found that since the headlight relay will not work with the key off, I wanted the fog lights to be the same, but on when the lights are off. I found a fuse that was key switched and used this to go to the switch activating the fog light relay, moving the wires from the headlight and over to the switched fuse. Then if the key is on the fog lights come on when I pull the green switch. If I forget to turn them off, they turn themselves on when I turn off the motor. You actually got both information and attitude. This is by far the most well moderator community I live with. Might hold off on making a judgement till a couple of questions in. These guys have gone the extra mile for me time after time, and they know. (IMG:style_emoticons/default/driving.gif) |
| SirAndy |
Aug 10 2014, 11:21 PM
I get it, I won't ask again. Jeeze, seriously? (IMG:style_emoticons/default/confused24.gif) Did you follow the link to pelican i posted? The numbers on the diagram refer to numbers that are printed on the back of the stock switches, gauges and relays. That, plus the colors of the wires should help matching the wires you have to the switch and lights. (IMG:style_emoticons/default/smile.gif) |
| screenguy914 |
Mar 18 2015, 06:26 PM
Member ![]() ![]() Group: Members Posts: 249 Joined: 6-July 09 From: So. Cal Member No.: 10,540 Region Association: Southern California |
I just modified my fog light circuit in my recently-acquired 914 six. After reading numerous docs on the mod., I didn't have that warm and fuzzy feeling nor did I want to let the smoke out of the wire harness, especially after a thread comment that the Haynes version of the 914 wiring diagram was inaccurate. Hmm. What version am I looking at on various websites? Wonderful.
In addition, there are apparently different versions of the light switch even with the same part number (914.613.414.10). This one has 10 spade connectors. There was a pic of this same switch (same part no.), but one of the connectors was labeled differently than mine. Did I want to remove all 10 wire connections to verify the term. ID? No, not even after recording wire colors with my camera. Later switches (e.g. '74) have 11 spade connectors (914.613.414.15). Thankfully, it appears wire color codes remained consistent over the years. Instructions suggest cutting a black/blue wire from a multi-wire connector (58R or 56) and transferring/piggybacking it to another wire/terminal (K or 15). However, different docs suggest different blk/blue wires. I didn't want to risk cutting the wrong one from the headlight harness only to discover it was the wrong one. So I verified the connector IDs by cross referencing the wire colors with the correct connector ID (58b, 58R, 30, 57, K, etc. ), charting voltage levels (0/12V) with the ignition and headlight switches in both ON and OFF positions. After some sleuthing with a DMM and test leads, I ended up making and installing a jumper wire with piggyback connectors to connect term. 56 to K. No vehicle wires were harmed in the process and thus able to return to the previous/next setup if necessary. Here are the results: Previous Ign Sw. ON Headlight Sw. 1st detent - parking lights ON; fog light switch inactive Headlight Sw. 2nd detent - parking lights ON; headlights pop up and ON; fog light switch active After rewiring: Ign Sw. ON or OFF Headlight Sw. 1st detent - parking lights ON; fog light switch active Headlight Sw. 2nd detent - parking lights ON; headlights pop up and ON; fog light switch active This setup provides some options and perhaps more clarity to activate the fog lights. Others may prefer the light circuit dependent on the ignition switch. YMMV. Next mini-project: Install a momentary toggle switch to the circuit to independently flash the fog lights OFF>ON. Hope this helps, Sherwood 3-22-15 Update: A more thorough night time road test revealed the above wiring connection has these repercussions: a. Instrument lights are No Op (NG) b. If: Ign. ON or OFF. fog lts. ON or OFF, with headlights ON: - Pressing Lt switch to the 1st detent (parking lts.) leaves the headlights ON (should be OFF). - High beam indicator is ON (headlights on low beam). Pulling the turn signal stalk momentarily switches the fog lights ON. c. Affect on emergency flashers is unknown (currently no op) Will have to either snip a wire per published wiring mods and confirm that strategy works on this chassis or rewire the fog light circuit independently from the light switch. Probably the latter. Perhaps an opportunity to install a ON-OFF-Mom ON lever switch in place of the factory fog lamp switch. Completion of project at post #35 |
| Cuda911 |
Mar 18 2015, 11:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
Very basic question here:
I've never pulled off the fog light grills on my '74. Can I assume the wiring's there? Is there a bulb housing back there? If not, where do I get one (well, two) and how much moola? Also, I would need the OEM dash switch. Are they readily available? Thx. |
| Larmo63 |
Mar 19 2015, 08:56 AM
Wiring is present behind the grilles. The switches are quite common too. The wiring is behind the dash above the headlight switch. You have to make a ground wire or even better, buy the JWest flasher kit on eBay. It is fairly straightforward. Fogs come up here on the board about once a week.
| Dave_Darling |
Mar 19 2015, 09:00 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Can I assume the wiring's there? Is there a bulb housing back there? Also, I would need the OEM dash switch. Are they readily available? Yes, no, and yes. The wiring will be in the trunk. Find it and push it through the rubber grommets to the area behind the bumper. You have to get the lights and brackets. Stock ones are available used for a moderate amount of money (or a lot more for ones in top condition) but there are popular brands of fog lights and driving lights (e.g., Pilot) that fit the stock location at least as well as the stock lights did. You have to find/fake/fab a mounting bracket for those, but some of those lights are quite cheap IIRC. The switches are available used. Not sure about new. Your favorite 914-specialist wrecking yard should have a pile of them. In my area, I'd call up Rich at High Performance House in Redwood City, or Partsheaven in Hayward, or EASY in Emeryville. I'm not sure, but I think the switch body can be substituted for one from a 911, but the knob is different. --DD |
| Cuda911 |
Mar 19 2015, 04:39 PM
Thanks, guys.
Any of you out there with some foggies for sale? If so, please PM me. If anyone has a link to some aftermarket ones that fit, that would be appreciated too. |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:02 PM |
