Fluid Leak: which seal? |
Stark 01 |
Aug 12 2014, 08:53 AM
Racing newbie Group: Members Posts: 43 Joined: 26-May 14 From: Concord, NC Member No.: 17,404 Region Association: South East States |
Cap'n Krusty |
Aug 12 2014, 09:03 AM
Kinda depends on what kind of oil it is. Tranny oil in that area could mean an input shaft seal, or maybe output flange seals. Engine oil could mean the flywheel seal and o-ring, the camshaft plug, or one of the oil galley plugs seeping. Or maybe that huge hole in the bottom of the engine ........................... (IMG:style_emoticons/default/sunglasses.gif)
The Cap'n |
JawjaPorsche |
Aug 12 2014, 01:32 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
Smell the fluid. Tranny oil or motor oil? That will be a good start to isolate.
Stark 01 |
Aug 12 2014, 04:03 PM
That made me laugh, Cap'n!
Confirmed it is gear oil, so now I must pick from what I will call List A. I'll have to see if I can rule some of them out. The gasket kit should be here any day now..... |
earossi |
Aug 12 2014, 04:28 PM
Member Group: Members Posts: 210 Joined: 8-December 11 From: Chicago, Il Member No.: 13,878 Region Association: Upper MidWest |
Either way, the tranny needs to come out. Once done, replacing in the front seal on it is easy and straight forward. If, instead, the oil is coming down the back side of the flywheel, you then have a few more items to remove. Be sure and lube the lip of the seal before installing it.
Stark 01 |
Aug 12 2014, 07:05 PM
Yes, I'm a bit nervous about that.
Looking into the notch made for the clutch engagement fork, it looks like there is oily residue on the fork itself but what I can see of the clutch is dry. I've got to get a better repair manual than the Haynes that I have.... |
rjames |
Aug 12 2014, 10:06 PM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
Yes, I'm a bit nervous about that. Looking into the notch made for the clutch engagement fork, it looks like there is oily residue on the fork itself but what I can see of the clutch is dry. I've got to get a better repair manual than the Haynes that I have.... There is no other manual. Best source of info is here, PelicanParts and the Haynes book you already have. |
bandjoey |
Aug 12 2014, 10:14 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Probably 100 threads here on tranny and motor work. Pictures are worth a thousand words.
Lo-Fi Version | Time is now: 8th June 2024 - 09:09 PM |
