Camber issue |
Camber issue |
akellym |
Aug 18 2014, 12:34 PM
Eyes Of The Deep Battle Group: Members Posts: 597 Joined: 25-July 04 From: Annandale, MN Member No.: 2,395 Region Association: Northstar Region |
I’m having a camber issue with the front and back of my 73 914. Here’s the alignment specs:
Front left: -0.5 Front right: -0.9 Rear left: -1.5 Rear right: -1.9 The shop says there is no more adjustment left on the front, so what are my options? The rear I’m assuming I can just add shims… Any help would be great, thanks! |
matthepcat |
Aug 18 2014, 12:51 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
I’m having a camber issue with the front and back of my 73 914. Here’s the alignment specs: Front left: -0.5 Front right: -0.9 Rear left: -1.5 Rear right: -1.9 The shop says there is no more adjustment left on the front, so what are my options? The rear I’m assuming I can just add shims… Any help would be great, thanks! Those numbers are ok in the front, but the rear is a bit aggressive. As long as you don't have any toe, you should not cook your tires with some negative camber. Shims should correct the rear camber issue. Matt |
akellym |
Aug 18 2014, 12:54 PM
I’m having a camber issue with the front and back of my 73 914. Here’s the alignment specs: Front left: -0.5 Front right: -0.9 Rear left: -1.5 Rear right: -1.9 The shop says there is no more adjustment left on the front, so what are my options? The rear I’m assuming I can just add shims… Any help would be great, thanks! Those numbers are ok in the front, but the rear is a bit aggressive. As long as you don't have any toe, you should not cook your tires with some negative camber. Shims should correct the rear camber issue. Matt There was to much toe and that has been corrected. I just wanted to make sure I'm not going to wreck the new tires going to RRC next month. |
Lo-Fi Version | Time is now: 9th June 2024 - 06:31 AM |
