> Converting fuel tank to AN hose - How To
patssle
post Aug 21 2014, 07:30 PM
I successfully found adapters that will fit on our fuel tanks, just wanted to share. No need to drill tap the tank - these fittings go on the existing threads. You can go to -6 or -8 AN. They come with an internal o-ring but I added thread sealant just for extra protection.
http://www.cbperformance.com/ProductDetail...roductCode=3288
http://www.cbperformance.com/ProductDetail...roductCode=3289
I plugged one with a cap and the other with a 90 degree AN to hose barb fitting if you don't want to use AN hose.
Replies(1 - 8)
Mike Bellis
post Aug 21 2014, 09:02 PM
Resident Electrician
I bought a pair of these too. -8 & -6 (supply & return) I'm happy there is a nice solution to rubber hoses on the tank. (IMG:style_emoticons/default/smile.gif)
JStroud
post Aug 21 2014, 09:19 PM
That's funny, I just installed mine today, now all my fuel lines are -6 AN (IMG:style_emoticons/default/shades.gif)
Jeff
Kansas 914
post Aug 22 2014, 09:16 AM
QUOTE(JStroud @ Aug 21 2014, 09:19 PM) *
Jeff
Jeff,
Do you have Chris' (Tangerine Racing) stainless steel lines? If so how did you transition to stainless?
JStroud
post Aug 22 2014, 09:52 AM
QUOTE(Kansas 914 @ Aug 22 2014, 08:16 AM) *
Jeff
Jeff,
I do have SS tunnel lines, I had McMark weld AN fitting on my SS lines.
I believe Chris sells SS lines with AN fittings on them.
Jeff
Kansas 914
post Aug 22 2014, 11:00 AM
QUOTE(JStroud @ Aug 22 2014, 09:52 AM) *
Jeff
Jeff,
Jeff
Yes - Chris will sell weld AN fittings for $26 each - and shows them in the engine compartment ends. Did you get the AN fittings through the rubber stock grommet at the forward firewall or do something else?
Thanks - hope to see you at RRC.
VaccaRabite
post Aug 22 2014, 11:23 AM
En Garde!
I have seen clamp-on AN fittings too for those of us with earlier Tangerine SS fuel lines. I considered using them, but decided to just use hose clamps and keep a $20 problem from snowballing into a $100 problem in AN fittings, etc.
Zach
patssle
post Aug 22 2014, 11:51 AM
QUOTE(Vacca Rabite @ Aug 22 2014, 09:23 AM) *
Yeah AN fittings and hose can add up in cost. And after dealing with -12/-16 AN with my /6 conversion - I'm done with that crap. I stuck a stainless line (that I bought from Tangerine nearly 4 years ago) in the tunnel and bought the best rubber fuel hose (Gates Barricade) on the market. I'm running carbs and low fuel pressure anyways.
Mike Bellis
You can get AN tube adapters for $15 to fit 5/16, 3/8 & 1/2 hard line. I'm running them in my car. (IMG:style_emoticons/default/smile.gif)
- Lo-Fi Version Time is now: 2nd April 2026 - 06:48 PM
