Distributor part number?, L-jet |
Porschef |
Aug 25 2014, 08:06 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Would I be correct in assuming that the distributor part number would be the same for 74-75 914's and the 76 911E? (IMG:style_emoticons/default/confused24.gif)
If so, what would be that number, Bosch and or VW? Thanks, Joe |
bdstone914 |
Aug 25 2014, 10:21 AM
bdstone914 Group: Members Posts: 4,531 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Would I be correct in assuming that the distributor part number would be the same for 74-75 914's and the 76 911E? (IMG:style_emoticons/default/confused24.gif) If so, what would be that number, Bosch and or VW? Thanks, Joe Are you trying to get a correct dizzy for a 912e? |
Porschef |
Aug 25 2014, 11:01 AM
Bruce, the Ljet on my car came from a 912e. I wasn't sure if they all had the same dizzy or not.
For some reason I recall a 009 prefix on the can, but it has a vacuum diaphragm with two ports. I could be wrong tho, wouldn't be the first time... |
Cap'n Krusty |
Aug 25 2014, 11:26 AM
Bruce, the Ljet on my car came from a 912e. I wasn't sure if they all had the same dizzy or not. For some reason I recall a 009 prefix on the can, but it has a vacuum diaphragm with two ports. I could be wrong tho, wouldn't be the first time... That would be a "009" "suffix", NOT "prefix". While the distributor and its vacuum can may be different from the 914 L-jet versions, it'll work. The advance curves will likely be different, but not that much. The Cap'n |
Porschef |
Aug 25 2014, 11:59 AM
Thanks Cappy, as I said, wouldn't be the first time... (IMG:style_emoticons/default/poke.gif)
Lo-Fi Version | Time is now: 2nd June 2024 - 02:52 AM |
