Question about gravity brake bleeding |
rosenfe |
Aug 27 2014, 02:43 PM
Senior Member Group: Members Posts: 561 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
Pmb recommends gravity brake bleeding,any opinions about this method?
Harpo |
Aug 27 2014, 03:50 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
I have heard of manual, power & vacuum brake breeding but never gravity bleeding.
David |
rosenfe |
Aug 27 2014, 04:34 PM
DRPHIL914 |
Aug 28 2014, 12:10 PM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
i used it , and it seemed to help get a lot of the air out of the system.
but i had some other issues. - note- you have to set the rear venting clearance - i ended up taking it to a local shop to do that and they power bled them. |
zipedadoo |
Aug 28 2014, 01:15 PM
Member Group: Members Posts: 135 Joined: 23-January 14 From: Arizona Member No.: 16,921 Region Association: None |
I rebuilt the rear calipers and used the gravity method to bleed the system. Worked great. Setting the venting clearance is easy too.
pcar916 |
Aug 29 2014, 06:06 AM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
It works. The only issue is that it leaves the system open to air/moisture for longer than I'd like. I'll take pressure bleeding any time.
wndsrfr |
Aug 29 2014, 06:21 AM
Senior Member Group: Members Posts: 1,430 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
dlee6204 |
Aug 29 2014, 06:37 AM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
If I have a dry system I usually start out gravity bleeding initially to prime the system. Then I finish it off the old fashion way.
GeorgeRud |
Aug 29 2014, 09:15 AM
When I replaced my calipers with rebuilt ones (thanks Eric), I had a heck of a time getting a firm pedal after bleeding. A long ride on a bumpy road followed by pressure bleeding finally did the trick for me, but gravity bleeding is certainly an easy, safe way to bleed the brakes as well. In the long run, whatever works to get rid of air in the system!
Lo-Fi Version | Time is now: 10th June 2024 - 08:45 AM |
