"Winking Headlight", Upon turning off headlights, the left one cycles up and down! |
Beeliner |
Sep 2 2014, 04:58 PM
Member Group: Members Posts: 398 Joined: 2-August 14 From: Fairfield, CT Member No.: 17,725 Region Association: North East States |
Everything seemed to be operating fairly well, until I turned off the lights and the left headlight cycled up and down and up and down.
I could stop it by holding it down for a moment until the motor paused. It is as if there was a flywheel effect that carried it from cycle to cycle.... Anybody have experienced this??? (IMG:style_emoticons/default/confused24.gif) |
Olympic 914 |
Sep 2 2014, 05:12 PM
Group: Members Posts: 1,677 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
check the linkage, mine used to go up then start back down. it was off a spline or two.
mramber |
Sep 2 2014, 06:50 PM
Member Group: Members Posts: 87 Joined: 14-April 13 From: Minneapolis, MN Member No.: 15,768 Region Association: Upper MidWest |
I had the same issue. Swap the relays from one light to the other and see if the problem follows. If it does then you have a bad relay, that was the case with mine
BeatNavy |
Sep 2 2014, 07:29 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
Everything seemed to be operating fairly well, until I turned off the lights and the left headlight cycled up and down and up and down. I could stop it by holding it down for a moment until the motor paused. It is as if there was a flywheel effect that carried it from cycle to cycle.... Anybody have experienced this??? (IMG:style_emoticons/default/confused24.gif) Mine does the same thing (it's the left one, too). I think it adds character (IMG:style_emoticons/default/smile.gif) |
mepstein |
Sep 2 2014, 08:22 PM
914-6 GT in waiting Group: Members Posts: 19,316 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
My 6 conversion started to wink after it took a small hit on the front left side. I wonder if it will still wink when the restoration is done.
It winked raising the headlights but not lowering. |
monkeyboy |
Sep 3 2014, 08:49 AM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
When mine did that, it was the headlight switch.
Dave_Darling |
Sep 3 2014, 09:02 AM
Sticky relay or bad microswitch inside the motor. I'm not sure how the linkage could cause this problem, but if someone has fixed it by adjusting the linkage it could have been the cause.
I'd start by swapping the relays left to right and see if the problem follows the relay. --DD |
toolguy |
Sep 3 2014, 04:32 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
The 'park' contacts in the motor are the most likely cause. . probably dirty. . swap out for a different motor assembly. .never tried to take one apart. .
Zippy69 |
Sep 4 2014, 11:49 AM
Member Group: Members Posts: 60 Joined: 18-March 12 From: NJ Member No.: 14,276 Region Association: None |
Check the green and grey wires on the headlight switch
914Mike |
Sep 4 2014, 02:24 PM
Member Group: Members Posts: 330 Joined: 27-January 03 From: San Jose, CA Member No.: 198 |
Relay is used to brake the motor at both the top and bottom position, by way of the Normally Closed contact. The other contact, Normally Open is working if the light goes up, but the N.C. contact will eventually burn out, causing the wink. Relays are mechanical, and N.C. contacts are only held in by a spring, while the N.O. is held by the magnetic force, usually much stronger, especially after the spring is 30 years old...
All the relays are the same, so if it is a relay, you can just swap it for one on the relay board. None of the other relays use the N.C. contact. |
Lo-Fi Version | Time is now: 10th June 2024 - 06:31 PM |
