Advance / Retard Vacuumn unit, Advance / Retard Vacuumn unit |
jayhilgers |
Sep 3 2014, 09:01 AM
I'm new here ... Group: Members Posts: 0 Joined: 25-May 14 From: Hollister Calif Member No.: 17,401 Region Association: Northern California |
hi Everyone..
First Thanks to all that I purchased parts from..My 76 912E is back on the road runnin good.. What I need is the Vacuumn Advance / Retard unit that mounts on the distributer. The diaphragm in mine is bad..I can manually put vacummn on it and I can feel it bubble and fail.. Makin settin idle near impossible..lol.. New or used..It doesn't matter as long as it works.. Ay Ideas Or Places I can look for it??..Not havin any luck locally.. FYI 2.0 calif car with stock bosch dist.. Oh I forgot to add that mine is fuel injected Thanks Jay Hilgers Here is my e-mail again just in case jayhilgers@att.net |
bdstone914 |
Sep 3 2014, 09:13 AM
bdstone914 Group: Members Posts: 4,528 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
hi Everyone.. First Thanks to all that I purchased parts from..My 76 912E is back on the road runnin good.. What I need is the Vacuumn Advance / Retard unit that mounts on the distributer. The diaphragm in mine is bad..I can manually put vacummn on it and I can feel it bubble and fail.. Makin settin idle near impossible..lol.. New or used..It doesn't matter as long as it works.. Ay Ideas Or Places I can look for it??..Not havin any luck locally.. FYI 2.0 calif car with stock bosch dist.. Thanks Jay Hilgers Here is my e-mail again just in case jayhilgers@att.net I am not sure which vacuum unit will fit that 912e distributor. I found that the l jet units in 1.8 engines have a different hole pattern than the d jet units. The l jet have a staggered pattern and d jet have two in line holes. |
jayhilgers |
Sep 3 2014, 09:38 AM
hi Everyone.. First Thanks to all that I purchased parts from..My 76 912E is back on the road runnin good.. What I need is the Vacuumn Advance / Retard unit that mounts on the distributer. The diaphragm in mine is bad..I can manually put vacummn on it and I can feel it bubble and fail.. Makin settin idle near impossible..lol.. New or used..It doesn't matter as long as it works.. Ay Ideas Or Places I can look for it??..Not havin any luck locally.. FYI 2.0 calif car with stock bosch dist.. Thanks Jay Hilgers Here is my e-mail again just in case jayhilgers@att.net I am not sure which vacuum unit will fit that 912e distributor. I found that the l jet units in 1.8 engines have a different hole pattern than the d jet units. The l jet have a staggered pattern and d jet have two in line holes. Thanks..I'm not sure either bings my car is fuel injected Jay |
bdstone914 |
Sep 3 2014, 03:40 PM
hi Everyone.. First Thanks to all that I purchased parts from..My 76 912E is back on the road runnin good.. What I need is the Vacuumn Advance / Retard unit that mounts on the distributer. The diaphragm in mine is bad..I can manually put vacummn on it and I can feel it bubble and fail.. Makin settin idle near impossible..lol.. New or used..It doesn't matter as long as it works.. Ay Ideas Or Places I can look for it??..Not havin any luck locally.. FYI 2.0 calif car with stock bosch dist.. Thanks Jay Hilgers Here is my e-mail again just in case jayhilgers@att.net I am not sure which vacuum unit will fit that 912e distributor. I found that the l jet units in 1.8 engines have a different hole pattern than the d jet units. The l jet have a staggered pattern and d jet have two in line holes. Thanks..I'm not sure either bings my car is fuel injected Jay Check the part number on the distributor. |
jayhilgers |
Sep 12 2014, 12:58 PM
hi Everyone.. First Thanks to all that I purchased parts from..My 76 912E is back on the road runnin good.. What I need is the Vacuumn Advance / Retard unit that mounts on the distributer. The diaphragm in mine is bad..I can manually put vacummn on it and I can feel it bubble and fail.. Makin settin idle near impossible..lol.. New or used..It doesn't matter as long as it works.. Ay Ideas Or Places I can look for it??..Not havin any luck locally.. FYI 2.0 calif car with stock bosch dist.. Thanks Jay Hilgers Bosch part # for distributer is 923 602 021 00 Vacuum unit part # is 923 602 924 00 Thanks Jay Here is my e-mail again just in case jayhilgers@att.net I am not sure which vacuum unit will fit that 912e distributor. I found that the l jet units in 1.8 engines have a different hole pattern than the d jet units. The l jet have a staggered pattern and d jet have two in line holes. Thanks..I'm not sure either bings my car is fuel injected Jay Check the part number on the distributor. |
Lo-Fi Version | Time is now: 28th May 2024 - 06:35 PM |
