Horn wire help, Early car |
OU8AVW |
Sep 9 2014, 02:18 PM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
OU8AVW |
Sep 9 2014, 02:19 PM
OU8AVW |
Sep 10 2014, 12:24 PM
Easy answer guys, please help....
mepstein |
Sep 10 2014, 12:58 PM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Early cars used the black plastic horn plunger, not a horn wire. Is yours a 71 or 72
SLITS |
Sep 10 2014, 01:05 PM
If yours is an early car, you have the wrong horn pad.
The early cars use a spring loaded sausage that drops into a hole in the steering wheel and forms the ground path. You can see the brown wire that is attached to the grounding ring that the sausage rides against. Here is a link to PP bad diagram ..Horn Sausage |
mepstein |
Sep 10 2014, 01:14 PM
Mike. I have the correct parts for you. The horn pad parts are free. The plastic plunger is $25 or whatever they go for from a parts supplier. Couple $ for shipping. Pm me with your address if you want it. Priority will get it to you by the weekend. Installation is 10 seconds.
Yours actually needs the longer plunger but that's the only picture I saw on pelican. PS - you also want to make sure you have the correct plastic spacer on the back of your wheel. It should have a metal turn signal cancel tab. Late models are plastic. I have plenty of them. Attached image(s) |
Lo-Fi Version | Time is now: 1st June 2024 - 06:12 PM |
