Swaybar Bushings…., What do the expert say? |
Larmo63 |
Sep 11 2014, 05:08 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
I'm installing stock sway bars front and back in a '73 914 and I'd like some recommendations on rubber vs urethane. Also,
are front and rear link bushings a different configuration? I don't want a squeaky ride. Thank you. |
76-914 |
Sep 11 2014, 05:38 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Your going to get some squeeking if you use poly.
EDIT: Warning, I am not an expert but I did made the mistake of installing them on my '73. |
Larmo63 |
Sep 11 2014, 05:56 PM
Are front and back drop link bushings different?
Mike Bellis |
Sep 11 2014, 07:23 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I run poly, no squeaks. A little talcum powder will reduce noise but I did not use any.
bdstone914 |
Sep 11 2014, 07:35 PM
bdstone914 Group: Members Posts: 4,537 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I'm installing stock sway bars front and back in a '73 914 and I'd like some recommendations on rubber vs urethane. Also, are front and rear link bushings a different configuration? I don't want a squeaky ride. Thank you. Front drop link bushings are rubber with steel inserts. The rear drop link bushings are a white plastic cup type. They don't squeak. I have seen the front bar bushings in Poly but I am not aware of anyone selling urethane sway bar drop link bushings. 914 Rubber sells the rear bar bushings. I prefer the WeltMeister front drop link bushings as they are a two piece that makes installation easy. I would get the OE Porsche rear drop link bushings. They are a PITA to install. Uro also makes them but I have had fit problems with most of their bushings. |
76-914 |
Sep 11 2014, 07:38 PM
I missed sway bar, (IMG:style_emoticons/default/headbang.gif)
colingreene |
Sep 11 2014, 10:30 PM
Senior Member Group: Members Posts: 729 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
id just go with rubber.
but if you choose to go with poly i have lube that will make it not squeek. |
drbill |
Sep 12 2014, 08:12 AM
Member Group: Members Posts: 58 Joined: 12-March 14 From: Fort Mill, SC Member No.: 17,110 Region Association: None |
I'm installing stock sway bars front and back in a '73 914 and I'd like some recommendations on rubber vs urethane. Also, are front and rear link bushings a different configuration? I don't want a squeaky ride. Thank you. Front drop link bushings are rubber with steel inserts. The rear drop link bushings are a white plastic cup type. They don't squeak. I have seen the front bar bushings in Poly but I am not aware of anyone selling urethane sway bar drop link bushings. 914 Rubber sells the rear bar bushings. I prefer the WeltMeister front drop link bushings as they are a two piece that makes installation easy. I would get the OE Porsche rear drop link bushings. They are a PITA to install. Uro also makes them but I have had fit problems with most of their bushings. I replaced the front and rear on my car. Used the Porsche plastic on the rear. Got replacement rubber for the front from AA. No way to put the steel inserts back in on the replacements as the hole is smaller, so I just installed without. The bolt was a snug fit. I assume that's the way to go. |
Lo-Fi Version | Time is now: 10th June 2024 - 06:54 PM |
