Late to Early Headlight Switch |
patssle |
Sep 12 2014, 09:06 PM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
Has anybody swapped out their late headlight switch to an early one that lacks the extra "56k" pin - what did you do with that wire? Also - do all the other wires swap evenly to the same numbers? I've looked at all the wiring diagrams and past threads - different wire colors and inconsistent info are driving me crazy trying to track down what goes to what. Surely somebody has done this swap?
bdstone914 |
Sep 12 2014, 09:16 PM
bdstone914 Group: Members Posts: 4,538 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Has anybody swapped out their late headlight switch to an early one that lacks the extra "56k" pin - what did you do with that wire? Also - do all the other wires swap evenly to the same numbers? I've looked at all the wiring diagrams and past threads - different wire colors and inconsistent info are driving me crazy trying to track down what goes to what. Surely somebody has done this swap? Why not use the right switch? I have both types. Do you have the right wire diagram for your year car? Swapping to a non standard switch does not sound like it will make it any more simple. |
patssle |
Sep 12 2014, 09:24 PM
I have an extra early switch (unknown condition). My late switch isn't working correctly. I figured a swap would be easy to test the early switch before tearing the late switch apart to attempt to fix.
Lo-Fi Version | Time is now: 11th June 2024 - 07:36 AM |
