Pedrini wheel cleanup Questions, Strange Holes? |
bandjoey |
Sep 25 2014, 10:40 AM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Have my whees back from the machine shop. They cut the centers to fit hub centric hubs. Here a few questions about the clean up before refinishing them.
All around the inside if the wheel are pairs of holes spaced about 4" apart. I'll probably fill them with JB Weld. Do you think they're from manufacture or prior repairs? And. After an hour is scrubbing with several wheel cleaners and scratch pads (IMG:style_emoticons/default/confused24.gif) the inside is still covered in years of soaked in grime. Short of sandblasting would it be ok to hit them with a brass soft wire wheel or the likes? What else works to get the grime off? And OK to file down and fill in the gouges with JB? Attached thumbnail(s) Attached image(s) |
messix |
Sep 25 2014, 06:24 PM
AKA "CLUTCH KILLER"! Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
try engine degreaser in a spray can.
bandjoey |
Sep 25 2014, 08:50 PM
Will do. Already used Purple and Green cleaners, aluminum wheel cleaner, brake dust remover and sandpaper. I'm down to the smooth surface but this stuff is down in the pores.
Any thoughts on jb weld in the gouges? Will it stay in or be thrown out? |
jcd914 |
Sep 25 2014, 10:13 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
The marks are from a tire changer. Some of the "Touchless" tire changers use an internal rim clamp that expands inside the barrel of the wheel.
So the tire is removed without touching the face or out lip of the wheel but the clamp bites into the inside of the wheel. Most of the rim clamp tire changer will also clamp the wheel by grabbing the inner lip between the wheel and tire but it requires the tech to apply a bit more force to hold the wheel down in place while clamping it. Might be too much work for some of them. Jim |
914bub |
Sep 25 2014, 10:25 PM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
That's what I was thinking too. I own a tire machine, that if the "tines" were sharp enough, would do the same thing. Mine is "touchless" and thats all that should be used these days. I own several ATS classic wheels that were broken, (centers), on a "traditional" tire machine,(like a Coats 40/40)....., by people who didn't know what they were doing. (IMG:style_emoticons/default/mad.gif) |
Lo-Fi Version | Time is now: 13th June 2024 - 02:48 AM |
