Vacume Hoses and Fuel Lines, Various questions |
Rhodes71/914 |
Jan 28 2005, 08:47 PM
Glacier Group: Members Posts: 1,374 Joined: 8-August 04 From: End of the Road, Alaska Member No.: 2,482 |
For my 75 2L D-jet.
Does any one know if a complete kit is available for all the vac hoses in the correct length, I read in a old thread that AA had them but their online cat. doesn't show. Also on Pelicans tech info they show that 176" of 12mm ID vac hose is needed, that's almost 15 feet (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) seems like a lot. For fuel hose do I have to use high pressure hose? Regular fuel line that I have is rated to 50psi and the D-jet runs around 30psi. Please enlighten me. |
Allan |
Jan 28 2005, 08:59 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
I'm very interested in this as well. I believe that buying by the foot and determining where they go will be the best way. I am not too concerned about the color because I know they will all be black after the first 500 miles.
Rhodes71/914 |
Jan 29 2005, 01:40 AM
markb |
Jan 29 2005, 03:02 AM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
As far as I know, you can't get much in the way of colors any more. I just did all of the fuel lines & vac hoses on my 72 djet this last week. It did take a lot of the 12mm. I'm lucky that I had a shop to do it in, and most was on hand. And the Cap'n to tell me what was what. If I didn't have the shop, I'd recommend going to your local Bug parts house & buy it there. Get the real german braided hoses, and the proper fuel lines. The PP hose diagram was very helpful, and the factory diagram was a big help too.
DJsRepS |
Jan 29 2005, 06:06 AM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
You can get any color you want Baby! Colored heat shrink Tubing not from Raido Shack. My fuel lines are yellow, The FI harness red and black and spiral wrap. The FI pressure port refrigeration brass service vlave, I use an old set of freon gauges to check my pressure.
Attached image(s) |
DJsRepS |
Jan 29 2005, 06:07 AM
Oops I ment red and yellow. The inj boots are large test lead boots.
Bleyseng |
Jan 29 2005, 10:14 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
Yup, go to a local VW parts house to source the vacuum hose. You shouldn't need 15 ft as you don't have the long hoses for the charcoal canister.
Use only the Porsche High pressure FI hose in the engine compartment. Anything else can't stand the heat!!!and will crack spraying gas onto the hot engine resulting in a fire. Use only the Porsche/VW fuel clamps as they don't crimp the fuel line or more fire can happen. Geoff (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) |
Rhodes71/914 |
Jan 29 2005, 02:17 PM
Thanks for the input y'all. Guess I'll have to order some more stuff. It's a PITA getting that stuff here, there is no real VW place here besides the dealer and they suck. I'll have to do some more searching, finding the metric sizesf here is not easy.
newdeal2 |
Jan 29 2005, 02:23 PM
Unregistered |
Why is the fuel rail plugged?? |
Bleyseng |
Jan 29 2005, 03:27 PM
Order them from GPR, PP, HPH or (gasp)AA. They ALL will sell you the correct parts/hoses. This is one area where it doenst pay to be cheapo.
While you are orderings parts, order a set of fuel injector seals and elbows, then you are set and safe. Geoff |
Rhodes71/914 |
Jan 29 2005, 03:55 PM
Bummer is I just got a package from PP yesterday with all the ignition stuff and various other parts to finish the motor. Thought I could find the hose local. Oh well overnight shipping wont be that much more, guess PP will get some more of my $, might as well spend enough to use that $20 off web coupon they emailed me. |
mattillac |
Jan 29 2005, 04:42 PM
robots! Group: Members Posts: 536 Joined: 27-October 04 From: vallejo,ca Member No.: 3,020 |
just look at the pp site and it'll be pretty easy to pick out which vacuum hose diameters
you'll need. order an extra foot or so of each. you might as well get some intake runner boots also. have fun putting the boots on. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) do you still have the old vacuum hoses? |
Lo-Fi Version | Time is now: 8th June 2024 - 12:21 AM |
