Rotors, Pads and Bears! Oh my!, Ok, no bears but I could use some recommendations |
ezbngreen914 |
Oct 9 2014, 07:02 AM
Member Group: Members Posts: 441 Joined: 11-December 10 From: Sautee, GA Member No.: 12,472 Region Association: South East States |
Time to change rotors and pads on my 73 1.7 stock 914. Any recommendations or cautionary tales? Thinking about getting a rebuild kit for the calipers while I'm at it. Anything else I should take care of at the same time. Thanks for any and all input!
stugray |
Oct 9 2014, 07:17 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
Replace the flex lines as well.
BeatNavy |
Oct 9 2014, 07:49 AM
A couple of thoughts from my experiences:
1. If you rebuild the rear calipers this video from Eric at PMB is an awesome resource: Caliper Rebuild. He's also a great source for brake parts. 2. (IMG:style_emoticons/default/agree.gif) I agree about replacing the flex lines. 3. If you buy the Textar brand brake pads they don't fit without some modification. Pelican notes that in their catalog, but I didn't see it, and nothing annoys me so much as buying a new part that doesn't fit well. Pelican did graciously accept a return and credited me toward the brand that fit without any modification 4. Rebuilding the front calipers can be a little more challenging just because it can be difficult to get the pistons out. There are different suggested methods. I tried to use compressed air method, and while I didn't hurt myself or anyone else in the process I did ruin the caliper and ended up buying rebuilt front calipers from someone else. Cautionary tale, and I can explain more if you'd like. There are other methods to accomplish this, apparently. 5. I like my power bleeder. I can bleed my brakes quickly without dragging a "volunteer" from my family out into garage to stomp the brakes. |
Dave_Darling |
Oct 9 2014, 08:41 AM
Note that very few pads have the asymmetric mounting holes that are required by the 914's rear caliper. Fortunately, it only takes a minute's work with a drill to enlarge one hole in each pad so that the retaining pins fit.
--DD |
ezbngreen914 |
Oct 9 2014, 09:13 AM
Thanks for the input everyone!
It appears that the flex lines have a date stamp on them of 2007 which coralates with the time when the PO pulled it out of storage and recommissioned the car. I still might want to upgrade... Still open for input... not ordering till tomorrow. |
r_towle |
Oct 9 2014, 10:50 AM
Custom Member Group: Members Posts: 24,585 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
Pmb performance has everything you need, and backs it up with lots of free advice.
Good vendor |
mepstein |
Oct 9 2014, 11:49 AM
914-6 GT in waiting Group: Members Posts: 19,305 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Pmb performance has everything you need, and backs it up with lots of free advice. Good vendor (IMG:style_emoticons/default/agree.gif) I've spent many $ there and will continue to do so. Money well spent. |
Lo-Fi Version | Time is now: 1st June 2024 - 06:23 AM |
