2-port fuel pump pictures, Show em if you got em... |
boxsterfan |
Oct 12 2014, 12:55 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
In my "Gas Tank Adventures" thread, I'm back at square one. So I thought I would ask the crowd to show me your 2-port fuel pump installation pics if you have done this?
In particular, this would apply to people who have converted from 3-port to 2-port pump and relocated the pump up front....although I am not opposed to moving mine back to the rear with some sort of heat shield maybe? |
JawjaPorsche |
Oct 12 2014, 03:58 PM
Advanced Member Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I moved my pump from original location under the battery area to the fire wall over 20 years ago. No need for a heat shield. Not one vapor lock since moving the pump.
Attached image(s) |
EdwardBlume |
Oct 12 2014, 04:29 PM
914 Wizard Group: Members Posts: 12,338 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California |
Mine is just like pictured above..... fixed to the engine wall.
sdthomas |
Oct 12 2014, 05:45 PM
Member Group: Members Posts: 64 Joined: 14-June 11 From: Seattle Member No.: 13,193 Region Association: Pacific Northwest |
I moved mine to the front and switched to the 2 port pump, using the Tangerine relocation kit. It's mounted in the space near the MC for easy filter changes.
Attached image(s) |
saigon71 |
Oct 12 2014, 06:53 PM
Advanced Member Group: Members Posts: 2,000 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region |
I too went with the firewall mount option. However, I have experienced vapor lock three times on very hot days. If I find a cure for vapor lock I will leave it alone. Otherwise, I'll move it up front.
Mike Bellis |
Oct 12 2014, 07:36 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
boxsterfan |
Oct 14 2014, 01:20 PM
I think I am going to move mine to the rear firewall. Looks much easier to deal with in the long run.
If I needed a heat shield (although nobody is reporting issues) it seems like fashioning up on would be pretty easy back there also. |
Mike Bellis |
Oct 14 2014, 01:32 PM
Porsche moved them to the front to eliminate vapor lock. Moving it to the rear may not work as well as you think.
JawjaPorsche |
Oct 14 2014, 01:37 PM
boxsterfan |
Oct 14 2014, 06:22 PM
Porsche moved them to the front to eliminate vapor lock. Moving it to the rear may not work as well as you think. Part of me would rather have vapor lock then to ever have to crawl up front and get at the fuel filter again. (IMG:style_emoticons/default/shades.gif) Moving it to the firewall (away from the direct output of the heat exchanger) suggests it will work fine. And putting up some sort of heat shield for a firewall mounted fuel pump looks rather simple... |
Lo-Fi Version | Time is now: 3rd June 2024 - 12:47 AM |
