relay for H4s?, I know this topic has been beat to death but.. |
Ben and Ralph |
Oct 13 2014, 11:23 PM
Ben Group: Members Posts: 110 Joined: 8-July 10 From: Los Angeles Member No.: 11,917 Region Association: Southern California |
So I know there are threads about H4s out there but I've gotten mixed answers from different people, so here it goes. Would I need to run separate relays for hella h4s like these
Someone told me that I should play it safe and get relays for them, Someone else said that the power is very close to the stock headlights and the switch should handle it, and a third someone told me to just run a thicker ground wire. Called Pelican and they are 55/60 watt. If I would need to run new relays, who sells a kit that I could purchase? |
Ben and Ralph |
Oct 13 2014, 11:30 PM
So I know there are threads about H4s out there but I've gotten mixed answers from different people, so here it goes. Would I need to run separate relays for hella h4s like these Someone told me that I should play it safe and get relays for them, Someone else said that the power is very close to the stock headlights and the switch should handle it, and a third someone told me to just run a thicker ground wire. Called Pelican and they are 55/60 watt. If I would need to run new relays, who sells a kit that I could purchase? Part number PEL-H4-70477 for 66$ |
Luke M |
Oct 14 2014, 09:58 AM
Senior Member Group: Members Posts: 1,377 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
You can buy all of the parts needed at your local auto parts store. Attached image(s) |
SirAndy |
Oct 14 2014, 10:50 AM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
H4 relays should be readily available from your local FLAPS, at least they were when i bought mine some 10 years ago.
Do *not* run H4 lights without relays! (IMG:style_emoticons/default/popcorn[1].gif) |
Mark Henry |
Oct 14 2014, 11:35 AM
H4 relays should be readily available from your local FLAPS, at least they were when i bought mine some 10 years ago. Do *not* run H4 lights without relays! (IMG:style_emoticons/default/popcorn[1].gif) Doesn't the stock circuit already have relays? (IMG:style_emoticons/default/confused24.gif) |
Johny Blackstain |
Oct 14 2014, 11:38 AM
Walnut Elite Stratocaster player Group: Members Posts: 3,434 Joined: 5-December 06 From: The Shenandoah River Member No.: 7,318 Region Association: MidAtlantic Region |
That's what I thought, so you have to wonder do you remove the original or just add 2 more in line? |
SirAndy |
Oct 14 2014, 12:47 PM
Doesn't the stock circuit already have relays? (IMG:style_emoticons/default/confused24.gif) Nope ... |
Java2570 |
Oct 14 2014, 12:52 PM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
I had always heard that the relays and heavy duty wiring were only necessary when using the
higher output bulbs in the H4's. I've had mine in for awhile without any mods on my part with no issues. Of course, I don't use them much because I don't drive at night often....YMMV. |
Ben and Ralph |
Oct 14 2014, 03:50 PM
I had always heard that the relays and heavy duty wiring were only necessary when using the higher output bulbs in the H4's. I've had mine in for awhile without any mods on my part with no issues. Of course, I don't use them much because I don't drive at night often....YMMV. Yeah, this car is my daily driver so I better put some relays in. I drive at night almost everyday. |
Dave_Darling |
Oct 14 2014, 04:02 PM
It has one--the high/low relay. But all of the power to the relay comes through the ignition switch and I think the light switch also. Asking those switches to carry more power is not a recipe for a long and happy life for them. You can run H4s without extra relays. I've done so for 20 years. They are low-powered H4 bulbs, though. And they would be brighter, and the other electrical bits would be happier and less stressed, if I ran relays like the ones shown in the diagram above. Running even the lower-powered ones is still quite sub-optimal. I would not try it at all with the higher-powered bulbs. --DD |
michael7810 |
Oct 14 2014, 06:43 PM
Senior Member Group: Members Posts: 1,081 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
Has anyone tried Nighthawks? I guess they would benefit from better voltage as other lights but these seem to draw way less juice than OEM or H4s and produce better (?) light.
GE Nighthawk |
phatnine11 |
Oct 14 2014, 08:16 PM
Member Group: Members Posts: 286 Joined: 22-March 05 From: Rancho Cucamonga, CA Member No.: 3,798 |
lonewolfe |
Oct 15 2014, 10:11 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
tnsmike |
Oct 15 2014, 10:40 PM
Newbie Group: Members Posts: 14 Joined: 15-April 14 From: tulsa Member No.: 17,257 Region Association: None |
I am running hella lenses with piaa xtreme white bulbs and have had no problems with stock wiring but I may need to look in to relays.
Phoenix914 |
Oct 16 2014, 07:11 AM
Member Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States |
It has one--the high/low relay. But all of the power to the relay comes through the ignition switch and I think the light switch also. Asking those switches to carry more power is not a recipe for a long and happy life for them. You can run H4s without extra relays. I've done so for 20 years. They are low-powered H4 bulbs, though. And they would be brighter, and the other electrical bits would be happier and less stressed, if I ran relays like the ones shown in the diagram above. Running even the lower-powered ones is still quite sub-optimal. I would not try it at all with the higher-powered bulbs. --DD Dave, your statement about power to the headlight relay coming through the ignition switch got me thinking. My headlights haven't been switching between high and low, and I just realized my ignition switch is bad (electric part). Could the headlight switching problem be related to the ignition switch? I have a new ignition switch, but haven't installed it yet. Maybe I will by the weekend and the question will be answered anyway. |
Dave_Darling |
Oct 16 2014, 10:51 AM
My headlights haven't been switching between high and low, and I just realized my ignition switch is bad (electric part). Could the headlight switching problem be related to the ignition switch? Probably not, if the lights are on but just not switching between high and low. The suspects in that case are the high/low switch in the turn signal stalk, and the high/low relay on top of the fuse panel. --DD |
Phoenix914 |
Oct 16 2014, 11:28 AM
Probably not, if the lights are on but just not switching between high and low. The suspects in that case are the high/low switch in the turn signal stalk, and the high/low relay on top of the fuse panel. --DD Ok. That narrows it down quite a bit. I replaced the relay on the fuse panel, but didn't realize there was also a switch in the turn signal stalk. It's likely my problem is there because of a wiring challenge in the past. I'll make sure there is 12V getting there. Thank you! (IMG:style_emoticons/default/biggrin.gif) Also, I asked this question because I am running H4s with no additional relays. |
Lo-Fi Version | Time is now: 8th June 2024 - 05:14 AM |
