More air to airbox? (cutting involved) |
Ferg |
Jun 2 2003, 12:12 PM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
I have on my 2.7 conversion a somewhat unique system. It is CIS but it is using a audi 80/rabbit airbox, see pic
http://www.theidiotsvillage.com/misc/car_p.../pict_pg_5.html I was told that I would benifit HP wise from better breathing. And that I should cut some circular holes in the bottom of the airbox, as well as enlargening the tubing that leads to the thorttle body. As you can see in the pic, the airbox opening is just above and below the large breather oil tube, and the tubing to the throtle body gets smaller in diameter closer it gets. Anyhow before I start messing with a very smooth running CIS I thought I would ask opinions. Ferg (IMG:style_emoticons/default/tongue.gif) |
J P Stein |
Jun 2 2003, 02:37 PM
I've never seen anything quite like that on a 6.
I wouldn't mess with it....till I had a Weber set-up in hand (IMG:style_emoticons/default/biggrin.gif) |
Scott S |
Jun 2 2003, 02:50 PM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
Hi Ferg -
We used to do that to our GTI's - LOTS of holes cut into the air box. I know your system is similar, but being that it seems to be really custom I would probably abstain - especially sonce the car in running well. The other thing we tried was rmoving the air cleaner. That actually hurt performance on the car. The big throttle body swaps are a joke as most people to not match port the intake manifold. If this is not done, there is no airflow increase. Your car seems to be very well thought out (per Brant the brakes alone are worth a fortune!) I wouldn't mess with it - other than flares and really big fuchs! (IMG:style_emoticons/default/biggrin.gif) |
Brad Roberts |
Jun 2 2003, 03:07 PM
Where is the AC compressor mounted ??
B |
Ferg |
Jun 2 2003, 03:15 PM
AC Comp is mounted underneath on the passenger side. Belt runs just under the tin (I think) and I don't know how they mounted it, But It does blow ice cold I used it the other day with the top of and it did feel good to have cool air blowin. I will get pic's of it soon. I lent my camera to a friend as soon as I get it back I will shoot some more pic's, car's changed a little since these photos.
Lo-Fi Version | Time is now: 2nd June 2024 - 10:55 AM |
