Starter Relay? |
Starter Relay? |
Lou W |
Jan 30 2005, 12:34 PM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
It looks like the PO had the starter relay relocated, is this a good thing? or should I put it back where it should go?
Attached image(s) |
Allan |
Jan 30 2005, 12:39 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Same situation I have. Gonna dump it.
See This This is so cool, just learned how to title the links!!! |
Mueller |
Jan 30 2005, 12:40 PM
search...this was talked about "many" times last week (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
put "ford" in.... |
Lou W |
Jan 30 2005, 12:52 PM
DJsRepS |
Feb 4 2005, 06:18 AM
Member Group: Members Posts: 431 Joined: 4-November 04 From: Sarasota Florida Member No.: 3,060 |
At least that was a relay and not a solonid as last week. It takes almost the same amp/volt draw from the key to run the seperate part as opposed to real solonid on the starter. The relay is an better answer for some one that did not want to deal with the real problem. I would wire it the OEM way and if it gives trouble then trouble shoot it with all of us. Check the ground strap on tranny and dremil wire wheel the main fuse holder and install all new fuses. May not fix a damn thing but it sure wont hurt.
SteveSr |
Feb 4 2005, 06:22 AM
Member Group: Members Posts: 203 Joined: 7-October 03 From: Knox,In. Member No.: 1,223 |
Me too!!! (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/mueba.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) it's awsome...... SteveSr |
SirAndy |
Feb 4 2005, 10:34 AM
Resident German Group: Admin Posts: 41,671 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
there never was a starter relay on our cars ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) this is aftermarket, so any position is probably just as good. one would *think* close to the starter is the way to go. be aware that people use this as a band-aid to mask problems in the electrical system that they couldn't figure out. might be as simple as the starter going out slowly, could be as bad as loose or broken wires somewhere else. the original circuit for the starter *does not need* a relay. (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
Lo-Fi Version | Time is now: 4th June 2024 - 06:10 AM |
