DRPHIL914 |
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,829 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States ![]() ![]() |
So this grey wire has melted insulation
And the #3 has no wire on the connector in one row. Also looks like some splicing and an extra one or 2 wires added with I think go to the radio I've never blown #5 fuse so I'm not sure when this happened. Attached thumbnail(s) ![]() |
DRPHIL914 |
Am I missing a wire? Should I be concerned
DRPHIL914 |
Another
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Looks like 5th position fuse.
Pelican parts has the wiring diagrams in the technical section. |
type47 |
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region ![]() |
You can see that #3 connection that is unused is connected to #4 with the yellow wire; if you look at the base, there is metal that runs between 3 and 4 so they are joined/connected/... common terminals. Hope that's understandable ... #1 and 2 are also common...
grey/blk on track 29 http://www.pelicanparts.com/914/parts/Elec...lectric_74C.jpg M1 = left parking light M11 = stop/parking light http://www.pelicanparts.com/914/parts/Elec...lectric_74A.jpg |
Lo-Fi Version | Time is now: 8th July 2025 - 12:45 PM |
