Full Version: sorting thru the wire maze - what is #5 grey with black stripe for
DRPHIL914
So this grey wire has melted insulation
And the #3 has no wire on the connector in one row. Also looks like some splicing and an extra one or 2 wires added with I think go to the radio
I've never blown #5 fuse so I'm not sure when this happened.
DRPHIL914
Am I missing a wire? Should I be concerned
DRPHIL914
Another
r_towle
Looks like 5th position fuse.
Pelican parts has the wiring diagrams in the technical section.
type47
You can see that #3 connection that is unused is connected to #4 with the yellow wire; if you look at the base, there is metal that runs between 3 and 4 so they are joined/connected/... common terminals. Hope that's understandable ... #1 and 2 are also common...
grey/blk on track 29
http://www.pelicanparts.com/914/parts/Elec...lectric_74C.jpg
M1 = left parking light M11 = stop/parking light
http://www.pelicanparts.com/914/parts/Elec...lectric_74A.jpg
