Porky |
Newbie ![]() Group: Members Posts: 10 Joined: 21-October 14 From: DC Member No.: 18,043 Region Association: MidAtlantic Region ![]() |
behind the driver's seat. there's the seatbelt wires, but also a black plug that looks like it should be hooked to something big. lots of wires going nowhere.
(IMG:http://www.914world.com/bbs2/uploads_offsite/i.imgur.com-18043-1415061587.1.jpg) |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 127,807 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
That's for the rust control unit. Most cars never got one. (IMG:style_emoticons/default/sad.gif)
914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,204 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
Seat belt interlock buzzer. Used on 74-76
Porky |
Seat belt interlock buzzer. Used on 74-76 cool. i don't really care about the seatbelt warning stuff at all. i've been wondering where to find some power for a hidden antenna "Requires a switched 12-volt power source" and/or a subwoofer. seems to be a nice bundle of wires already going to the front trunk for the a/c. |
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
Flux capacitor is missing.
That is why you are still here asking the same question you asked yesterday. It's a complex Groundhog Day thing. |
Porky |
Flux capacitor is missing. That is why you are still here asking the same question you asked yesterday. It's a complex Groundhog Day thing. ahh. well there's one that plugs into the lighter and has usb ports. i'll just have to get that one. http://www.thinkgeek.com/product/1dbd/?itm...CFWcF7AodGEYAfg |
Rand |
Cross Member ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,413 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None ![]() |
Did you mean passenger seat? (That's where the seatbelt relay junk is.)
You can cut all that out, join the big yellow and forget about the junk. Although it's a good idea to join all the brown wires because you could have some weird ground problems if you don't. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,276 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
You can cut all that out On a street car, i would highly advise *against* cutting any wires at all. There really is no need to cut anything ... (IMG:style_emoticons/default/dry.gif) |
Porky |
Did you mean passenger seat? (That's where the seatbelt relay junk is.) You can cut all that out, join the big yellow and forget about the junk. Although it's a good idea to join all the brown wires because you could have some weird ground problems if you don't. well, the wires are long enough that they could easily go behind the passenger's seat. but i found 'em behind the driver's. |
Rand |
Respect Andy. But if they go nowhere to anything in use, it doesn't matter. But this is exactly why I mentioned joining the ground wires, which is the one possible thing that can cause trouble.
Sigh. Use your own judgement I guess. I know what has worked for me. BTW, I don't recommend this in general. Don't hack your wiring. But that cluster fuck under the passenger seat is an exception. It's caused way more problems than it's worth. |
Porky |
Respect Andy. But if they go nowhere to anything in use, it doesn't matter. But this is exactly why I mentioned joining the ground wires, which is the one possible thing that can cause trouble. Sigh. Use your own judgement I guess. I know what has worked for me. BTW, I don't recommend this in general. Don't hack your wiring. But that cluster fuck under the passenger seat is an exception. It's caused way more problems than it's worth. well i know less about wiring and electricity than i do about cars, so that's very little. i've put in a car stereo before and can change oil and spark plugs, but that's about it. hoping to learn a little from the 914 without breaking anything. i have an electrician cousin nearby who might be bored enough to help me out. i see a 914 modern fuse box upgrade on ebay. is that worth messing with? |
Rand |
Respect Andy. But if they go nowhere to anything in use, it doesn't matter. But this is exactly why I mentioned joining the ground wires, which is the one possible thing that can cause trouble. Sigh. Use your own judgement I guess. I know what has worked for me. BTW, I don't recommend this in general. Don't hack your wiring. But that cluster fuck under the passenger seat is an exception. It's caused way more problems than it's worth. well i know less about wiring and electricity than i do about cars, so that's very little. i've put in a car stereo before and can change oil and spark plugs, but that's about it. hoping to learn a little from the 914 without breaking anything. i have an electrician cousin nearby who might be bored enough to help me out. i see a 914 modern fuse box upgrade on ebay. is that worth messing with? Well then don't do any cutting. There are a couple great upgrades for the fuse panel to modern blades. One is Jwest. Can't remember the other off the top of my head. Search will turn it up. What's the brand on the ebay one you saw? |
gifted914 |
middleagecrisis ![]() Group: Members Posts: 30 Joined: 17-April 13 From: Australia / Brisbane Member No.: 15,778 Region Association: Australia and New Zealand ![]() |
AH, AH, These control wires go to the explosive device for the 7 airbags.
DO NOT CUT !!!!! (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/piratenanner.gif) |
falcor75 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,579 Joined: 22-November 12 From: Sweden Member No.: 15,176 Region Association: Scandinavia ![]() ![]() |
General rule of thumb: If it aint broke....dont mess with it... (IMG:style_emoticons/default/smile.gif)
Lo-Fi Version | Time is now: 31st July 2025 - 09:24 AM |
