> where ic cylinder 1234 on my 912e
rosenfe
post Nov 11 2014, 07:20 PM
im going to adjust valves and have got tdc and all that figured out,but the 912e site gives a different layout than haynes for 914.so ,if you number cylinders by the haynes book,# 1 is on drivers side rear,#2 drivers side front,#3 passenger side rear and #4 passenger side front.this has got to be the correct order for 912e?
i feel stupid asking this.cannot find any stamping on tins
Replies(1 - 7)
bdstone914
post Nov 11 2014, 07:55 PM
bdstone914
Cylinders are in the same location relative to the engine but with the 912 engine facing the opposite direction it is all reversed relative to driver-passenger, front- rear. The distributor should have a notch on the rim indicating #1 cylinder. Look at the terminal in the cap that aligns with that mark. Follow that plug wire to #1.
bdstone914
bdstone914
Duplicate post
Bob L.
post Nov 11 2014, 07:57 PM
Remember that the engine is facing the other direction from a 914. Mid Vs. rear engine. The cylinders will be diagonally opposite from where they are in a 914.
McMark
post Nov 11 2014, 08:25 PM
914 Freak!
Cylinder #1 is passenger side towards the front of the vehicle (near the transmission).
Cylinder #2 is passenger side towards the rear of the vehicle (near the fan).
Cylinder #3 is opposite #1 (drivers side front)
Cylinder #4 is opposite #2 (drivers side rear)
This is for a 912E.
Cap'n Krusty
post Nov 11 2014, 10:40 PM
Cap'n Krusty
If you use my method as outlined in the classic posts section, it doesn't matter. Easier, too, and faster.
The Cap'n
Dave_Darling
post Nov 11 2014, 10:46 PM
914 Idiot
Does the 912E engine tin have cylinder numbers embossed in it like the 914 tin does?
--DD
rosenfe
post Nov 11 2014, 11:23 PM
i got it now.should have number on tins,but i couldnt find them.thanks all
- Lo-Fi Version Time is now: 14th March 2026 - 12:17 AM
