Color Of Pan, What is the correct color of the pan for a bumblebee |
rstover |
Nov 12 2014, 04:32 PM
Member Group: Members Posts: 136 Joined: 15-November 11 From: Kerrville, TX Member No.: 13,785 Region Association: Southwest Region |
I searched but did not find what the correct color of the pan of a Bumblebee. The car is at the shop and I am having the enging bay and rear fender wells cleaned and painted. The engine bay and fender wells we are going with satin black. But, the bottom of the trunk I believe is a gray primer color. Was this grey primer color also used for the main pan from tow hook to the engine bay?.. I have the Dr. Johnson Reatores guide but I did not see it in the book. Thanks for any help.
JeffBowlsby |
Nov 12 2014, 04:48 PM
914 Wiring Harnesses Group: Members Posts: 8,548 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Its all L041 gloss black.
Where you see that great under the trunk bottom and pan, is just surfaces that did not get painted. To be authentic, you might try to match the grey where it occurs and the black where it occurs, there should be black overspray where the grey and black meet, not highly precise. Satin Black is not correct for the engine bay or fender wells. Suggest you keep them L041 gloss black like the rest of the car. |
rstover |
Nov 12 2014, 05:44 PM
Its all L041 gloss black. Where you see that great under the trunk bottom and pan, is just surfaces that did not get painted. To be authentic, you might try to match the grey where it occurs and the black where it occurs, there should be black overspray where the grey and black meet, not highly precise. Satin Black is not correct for the engine bay or fender wells. Suggest you keep them L041 gloss black like the rest of the car. Thanks Jeff this helps a lot. |
Lo-Fi Version | Time is now: 16th June 2024 - 04:10 AM |
