> Where can I find another pair of these?
cary
post Nov 13 2014, 10:15 PM
I put these rubber bushings in the car 12 years ago. I can't remember where I got them. Or what they're called.
Replies(1 - 12)
malcolm2
post Nov 13 2014, 10:19 PM
look too small to be suspension bushings.... if they are, I like mine from elephant racing.... all rubber, all the time. If they are not, then I am out of guesses. (IMG:style_emoticons/default/confused24.gif)
cary
post Nov 13 2014, 10:57 PM
Sorry, they're firewall fuel line grommets.
r_towle
post Nov 13 2014, 11:18 PM
Custom Member
Dealer, or plumbing isle of a good hardware store.
pilothyer
post Nov 13 2014, 11:19 PM
Tangerine Racing HERE
cary
post Nov 14 2014, 09:05 AM
That's Plan B. I just like the step design so it doesn't push thru the hole.
I have Cary Made steel truck brake lines as my fuel lines. So I know I got the grommet/bushing at NAPA or the hardware store in Montana.
I did a quick walk thru at ACE. Didn't find them on the first pass thru.
DBCooper
post Nov 14 2014, 09:27 AM
14's in the 13's with ATTITUDE
I don't recognize those specifically, but they're industrial and called "bulkhead grommets". Search online for the images and they should pop up.
cary
post Nov 14 2014, 02:47 PM
That's the info I was looking for. Thanks.
malcolm2
post Nov 16 2014, 01:10 PM
Can't tell on yours but if they are fuel lines on an early car might be 2 different diameters.
r_towle
post Nov 16 2014, 07:21 PM
Custom Member
QUOTE(cary @ Nov 14 2014, 10:05 AM) *
You did not look in the little drawers in the plumbing isle...did you?
My local ACe has loads of rubber grommets.
cary
post Nov 16 2014, 08:11 PM
No. I was only in the hardware section. I'll look in the plumbing section on Thursday.
Mikey914
post Nov 17 2014, 01:17 AM
The rubber man
They look kind of like the top of the brake master cylinder rubber?
ACE does have some generic stuff that might work.
cary
post Nov 19 2014, 08:32 PM
Mystery solved ...............................
Went downtown to Winks Hardware, my go to odd item hardware store. No luck. I did buy 4 powercord tubes that I might get to work.
So I stopped at Rothsport and picked Jeff's brain. It took about one nano second. Thats the firewall bushing for both the 914 and 911 plastic fuel lines.. He did a quick check on the PET. NLA. At a closer look it acually had the part number embossed on it.
- Lo-Fi Version Time is now: 31st July 2025 - 10:59 AM
