smart battery charger, what are you using, any recommendations? |
draganc |
Nov 29 2014, 05:06 PM
Senior Member Group: Members Posts: 725 Joined: 2-November 09 From: central new jersey Member No.: 11,000 Region Association: North East States |
My HF battery charger crapped out on me after 3 years - I guess it lasted long enough.
Looking for a smart battery charger recommendations, NOT tender. Budget; $50-100 Thanks, DC |
GeorgeRud |
Nov 29 2014, 07:02 PM
I've had good luck using a Bettery Tender by Deltran, though I think there are some newer designs out there that may be 'smarter'. It may also depend on the type of battery you have in your car as the AGM ones may need a different type of charger.
PThompson509 |
Nov 30 2014, 12:02 PM
Member Group: Members Posts: 132 Joined: 9-August 05 From: Santa Cruz, CA Member No.: 4,564 Region Association: Northern California |
I also use Battery Tender - they have a lot of different models but one thing they are all good at is not drying out your battery. I've had one in my wife's 911 for 15 years now - works great! The one in my 914 is about 8 years old now.
struckn |
Nov 30 2014, 08:56 PM
Senior Member Group: Members Posts: 1,069 Joined: 9-November 11 From: South Central York Pennsyvania Member No.: 13,764 Region Association: MidAtlantic Region |
My HF battery charger crapped out on me after 3 years - I guess it lasted long enough. Looking for a smart battery charger recommendations, NOT tender. Budget; $50-100 Thanks, DC DC, From your comment "NOT TENDER", what is your concern? I use, as do most the "Motor Tender". It will slowly recharge a dead battery then switch automatically to the Tender Mode. Other then a Battery Tender, Most new Battery Chargers are the same but look for one with a Meter, and either a Timer, or Automatic Drop Off Charge when fully Charged. Also Dual rated is nice to have for switching from either 2Amp or 10Amp, and 6 Volt or 12 Volt. If charging Deep Cycle Batteries a slow 2A Charge is best if you're not in a hurry. Remember that with Car Batteries when charged quickly they heat up and Vent which for a 914 is not a good thing, if you don't want rust. |
Eric_Shea |
Nov 30 2014, 08:59 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I've been really happy with BT Jr.'s on everything. Did you have a problem with one?
URY914 |
Nov 30 2014, 09:20 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,980 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
There is a lot of bad talk about Battery Tenders on the web. Check out buyer feedback on Amazon.
The Schumacher brand seems to get high marks. |
EdwardBlume |
Nov 30 2014, 09:42 PM
I've had rotten luck with BTs. Now I just try to keep it charged.
JmuRiz |
Nov 30 2014, 09:45 PM
914 Guru Group: Members Posts: 5,433 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I've used/have a battery tender (motorcycles and my old MB), Schumacher (914), and C-TEK (6-V for the 356). C-TEK has some really cool features and I'd buy another when I have to.
They all work just fine, however. All mine are old school batteries, not sure how an Optima works with different types. Side note: best thing ever is a jump box. I wish they made a battery charger that could jumpstart when plugged into a wall... |
cary |
Nov 30 2014, 09:56 PM
I like Eric use BT Jr's. Have worked really well.
One on the 914, one on the 911, one on my bench battery, one on my 4-wheeler and one on the riding lawn mower. |
eric9144 |
Nov 30 2014, 11:22 PM
Advanced Member Group: Members Posts: 2,734 Joined: 30-March 11 From: San Diego, CA Member No.: 12,876 Region Association: Southern California |
I have a bunch of vehicles and have nearly everything on a tender of some sort. For a long time the best thing out there was the Deltran Battery Tender...however will so many tech changes in the battery market the offerings have changed and now there are better options.
For the most part the BT's are a perfect solution, however they don't do it all and do have some short comings. Recently other players have hit the market and offer more features than "just" float charging, like desulfation and various battery checks, reconditioning etc... If I had nothing and was going to buy one, I'd buy a CTEC for $57 because it does all those "extra" things and does them quite well... http://www.amazon.com/gp/product/B006G14FK...=UTF8&psc=1 Battery Tender $47.99 http://www.amazon.com/Deltran-Battery-Tend...=Battery+tender I currently have 5 BT's and the one CTEC so I tend to move the CTEC around monthly. The CTEC is AGM and gel battery friendly (works great on my 10+ yr old optima). Buy a CTEC (IMG:style_emoticons/default/smoke.gif) |
eric9144 |
Nov 30 2014, 11:25 PM
I wish they made a battery charger that could jumpstart when plugged into a wall... Check these out, have seen them in use in person and I'll be buying one shortly, amazing power tech! http://themicrostart.com |
Rleog |
Dec 1 2014, 05:10 AM
Senior Member Group: Members Posts: 608 Joined: 12-October 03 From: Middleton, MA Member No.: 1,239 Region Association: North East States |
I had a BT Jr. for quite awhile and liked it. When it quit working, about 6 months ago, I bought a CTEK Multi US 3300 from Amazon. As Eric mentions above, it's a better unit.
Phoenix914 |
Dec 1 2014, 07:47 AM
Member Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States |
Here is another option in smart battery chargers.
http://tecmate.com/ I don't have experience with one, but I plan to buy one at some point. Honda has branded the Optimate 3 model with their name and sell them in Honda motorcycle shops. |
SLITS |
Dec 1 2014, 01:00 PM
I use the HF one that says not to use it on Gel Cell or AGM batteries.
Haven't ruined my Optima yet. |
draganc |
Dec 1 2014, 01:42 PM
Thanks for all the inputs!
I use battery tenders on my bikes w/o problems. However, if I have a empty battery, the tender takes forever to charge it, hence my "not" tender comment. My dad use to have a "smart" charge that would charge the battery and than switch to a tender mode, that's what I'm after now. Thanks again! |
eric9144 |
Dec 1 2014, 02:59 PM
However, if I have a empty battery, the tender takes forever to charge it, hence my "not" tender comment. That was also my problem--I'm 'baby sitting' my brother in law's truck while he's on deployment (Navy) and I had the battery tender on the truck...Little did I know the battery was actually failing and the tender thought all was OK. Green light on tender, dead cell on battery, no start (IMG:style_emoticons/default/dry.gif) |
draganc |
Dec 1 2014, 04:04 PM
I guess I have boiled it down to following two options:
http://www.amazon.com/Schumacher-SE-1555A-...battery+charger or http://www.amazon.com/Schumacher-SSC-1000A...ywords=SSC-1500 Any comments? 50/50 joker? phone joker? |
Steve |
Dec 1 2014, 04:22 PM
914 Guru Group: Members Posts: 5,607 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I guess I have boiled it down to following two options: http://www.amazon.com/Schumacher-SE-1555A-...battery+charger or http://www.amazon.com/Schumacher-SSC-1000A...ywords=SSC-1500 Any comments? 50/50 joker? phone joker? Thanks for sharing!! I am a cheap bastard.... I have a Sears battery charger to test and charge the battery and I also rewired the cigarette lighter fused to the battery. This allows me to plug a battery maintainer directly into the cigarette lighter to maintain the battery. Quick and easy between hibernation's!! |
eric9144 |
Dec 1 2014, 04:57 PM
The smaller one is rated better overall, also is 3# compared to 30# so moving it around is easier, has all the wiz bang features, desulfation, reconditioning, speed and trickle etc...
That and the fact that they wont sell them in CA tells me it must be good (IMG:style_emoticons/default/happy11.gif) |
thelogo |
Dec 1 2014, 05:12 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
[quote name='draganc' date='Nov 29 2014, 03:06 PM' post='2116378']
My HF battery charger crapped out on me after 3 years - I guess it lasted long enough. Looking for a smart battery charger recommendations, NOT tender. Budget; $50-100 Thanks, DC [/quote http://m.homedepot.com/p/BLACK-DECKER-120-...mp;gclsrc=aw.ds This is only 20 bucks and had been great for me . Shout out to the cheap sob |
Lo-Fi Version | Time is now: 3rd June 2024 - 11:09 AM |
