> using newer steering column in '70 chasis, got some pics and questions
buck toenges
post Dec 3 2014, 10:54 AM
Here are some pics from my '70 914 that has a newer steering column put in. You will notice that the steering column support has been cut out on the bottom. I have also taken some pics of the joints. What has to be done to make this work? I do think that there is a "clunk" going on as I turn the steering wheel. I think it is the shafts or the joints hitting the dash area but I am not sure.
What is the difference between the newer chassis and older chassis that makes a difference with the steering column?
Replies(1 - 1)
post Dec 3 2014, 12:15 PM
Resident German
The shafts have to be re-notched. The length and angle is different between the years.
The "clunk" you hear is the u-joints binding and the constant pull you're putting on the rubber steering coupler will result in premature failure of the coupler.
I went through all this several years ago when i put a '74 column in my '70 car.
(IMG:style_emoticons/default/dry.gif)
- Lo-Fi Version Time is now: 12th July 2025 - 12:06 PM
