| saigon71 |
Dec 7 2014, 09:31 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,019 Joined: 1-June 09 From: Dillsburg, PA Member No.: 10,428 Region Association: MidAtlantic Region
To the collective world knowledge database...
What is the largest size type IV that can built and used safely as a street car without adding an external oil cooler? Thanks! |
| Dave_Darling |
Dec 7 2014, 11:29 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,326 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Depends on a whole lot of factors. The overall efficiency of the engine spec, state of tune of the engine, ambient temps it will be driven through, etc.
I know that a mis-tuned stock motor can require an external oil cooler when driven through Grant's Pass in the summer. And a decently-tuned bone-stock 2.0 can require a cooler when driving through the desert in the summer. --DD |
| Mueller |
Dec 7 2014, 12:05 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,155 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Dave,
Does adding piston squirters put more load on the stock cooler and necessitate an external cooler? |
| Starlack |
Dec 7 2014, 12:07 PM
Member ![]() ![]() Group: Members Posts: 67 Joined: 8-January 12 From: Germany Member No.: 13,978 Region Association: None |
I had a 2,4Liter engine with 160 HP . First i drive with this Engine without front oil cooler. Not possible.
In the engine oil temperature immediately goes into the red zone. Better with front oil cooler but you really have to watch out for the temerature. The current engine 2,7 typ 4 has a front oil cooler and a fan from the 911 No problems with the oil temperature no matter how I drive |
| Mark Henry |
Dec 7 2014, 12:12 PM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
If it is built correctly you likely don't need one in your area, unless you are racing and pulling more then say 3800rpm for long periods of time.
My 2.6 has no over heat issues. |
| Mueller |
Dec 7 2014, 12:39 PM
| Mark Henry |
Dec 7 2014, 03:12 PM
Yes and no, because I've built both with no over heat issues.
Do not use over 96mm P&C's without Nickies. Any bigger is automatically a misconfigured engine in my book. That's a pretty basic rule, why Porsche when to an all aluminum cylinder as their engines got bigger. Adding an oil cooler not really going to help a misconfigured engine, maybe a bit but it's a bandaid solution. Also maybe you need one in socal, etc., but I'm taking into account the OP's location. |
| r_towle |
Dec 7 2014, 04:36 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Yes and no, because I've built both with no over heat issues. Do not use over 96mm P&C's without Nickies. Any bigger is automatically a misconfigured engine in my book. That's a pretty basic rule, why Porsche when to an all aluminum cylinder as their engines got bigger. Adding an oil cooler not really going to help a misconfigured engine, maybe a bit but it's a bandaid solution. Also maybe you need one in socal, etc., but I'm taking into account the OP's location. Now that LN makes nickies, it's a new possibility if you have the money. For many years, something like 30 years, building 103mm cast iron cylinders was the norm and a typical configuration. With cast iron cylinders, you really do need a front cooler. With the nickies, it may help, but I have no experience with the nickies.... I do not consider using cast iron cylinders a mis configured motor or design.....it's just a cheaper way to go that has been proven to last by many builders, many motors etc. I agree to disagree with Mark on that statement. Rich |
| colingreene |
Dec 7 2014, 06:59 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 749 Joined: 17-October 13 From: Southern California Member No.: 16,526 Region Association: Southern California |
Crap wrong thread.
| crash914 |
Dec 7 2014, 07:04 PM
its a mystery to me ![]() ![]() ![]() Group: Members Posts: 1,830 Joined: 17-March 03 From: Marriottsville, MD Member No.: 434 Region Association: MidAtlantic Region |
103 Nickies, I need an oil cooler...gets real hot real fast if you are romping on it...
| Mark Henry |
Dec 7 2014, 08:43 PM
| mepstein |
Dec 8 2014, 07:20 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,532 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
It can get hot here in the summer. And my worry would be a summertime traffic jam. Not uncommon on the way to the beach, driving through a city or just the wrong time/wrong place/accident/road construction. Crawling along for 5-10 miles on a hot summer day on the blacktop will heat up any engine. Got to plan for the possibilities.
| crash914 |
Dec 8 2014, 10:56 AM
I get hot with just street driving. Now I do keep high revs in a higher gear...like 6k in second..
| ClayPerrine |
Dec 8 2014, 12:07 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
Yes and no, because I've built both with no over heat issues. Do not use over 96mm P&C's without Nickies. Any bigger is automatically a misconfigured engine in my book. That's a pretty basic rule, why Porsche when to an all aluminum cylinder as their engines got bigger. Adding an oil cooler not really going to help a misconfigured engine, maybe a bit but it's a bandaid solution. Also maybe you need one in socal, etc., but I'm taking into account the OP's location. Mark, you may never need one considering the average summer temp for Port Hope, Ontario is 25 degrees C (77 degrees F) . Kinda like Germany for climate. Betty's stock 1.8L needs an external oil cooler for two reasons. 1. Because the average summer temp is 102 degrees F (38.8 degrees C). and 2. The AC load on the car increases the engine temp. I run the oil cooler without a thermostat, because it doesn't get cold enough in the winter to need one. (It is 53 degrees F today, December 8th.) Before you start yelling about a mis-configured engine, I have everything set according to factory specs, including the CO. The 914 owners in the desert southwest need an external oil cooer more than the Texas owners do. So it all depends on where you live. The 914 was designed with temps in Germany for the cooling load, so adding a cooler should be based on the regular oil temps you run on a regular basis. If it is too high, add the cooler. |
| Mark Henry |
Dec 8 2014, 03:55 PM
Yelling? Would you like to discuss your feelings? Panties bunching up? Do you need a Midol?
Then we all know it starts snowing right at the Canadian border. (IMG:style_emoticons/default/rolleyes.gif) You are changing the perimeters of the OP's question to suit your POV. PA is only about 300 miles south of here as the crow flies. Also the OP never mentioned that he has AC And BTW read the last line in that quote you posted, (sorry I only put Texas as an etc, my bad): QUOTE Also maybe you need one in socal, etc., but I'm taking into account the OP's location. |
Lo-Fi Version | Time is now: 11th March 2026 - 01:26 PM |
