| 76-914 |
Dec 11 2014, 09:07 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,985 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Elliot gave me this adp awhile back and I don't know what to do with it. (IMG:style_emoticons/default/slap.gif) What do I need to buy to complete the collapsible spare for my 4 bolt suspension. It is a 4x5 lug adp. On the 5 lug pattern the holes are 3"nominal C-C. I know the 4 bolt pattern is the 914. TIA
| GeorgeRud |
Dec 11 2014, 10:16 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Though I've never heard of anyone dismounting and mounting a collapsible spare on a different rim, I imagine you could just get another four bolt steel rim and mount the collapsible spare on that rim. Much easier than playing with adapters.
| Dave_Darling |
Dec 11 2014, 11:22 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,364 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I'm not sure exactly what the question is...
The 914 has a 4x130mm bolt pattern. The 911 (and 944 and 928 and lots of other Porsches) use a 5x130mm pattern. Not sure what your 5x3" pattern is from. --DD |
| Mike Bellis |
Dec 11 2014, 11:27 PM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
Porsche recommends the collapsible spare be replaced every few years. I saw my friends 2004 Cayenne spare inflate and push sideways off the rim instead of inflating directly over the rim. We deflated it and stood on the rim to hold the tire down. It lifted us off the ground as one side wall inflated correct and the other did not. Completely unusable.
If you can find a replacement tire to put on a 914 rim? I think Elliot did this on a 5 lug Fuchs. |
| Elliot Cannon |
Dec 11 2014, 11:32 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
Not a fuchs. Just a spare from a 911. Don't know what year. Some tire shops will re-mount a collapsible spare for you on to another rim but apparently it's kind of a PITA.
| messix |
Dec 12 2014, 12:02 AM
AKA "CLUTCH KILLER"! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,995 Joined: 14-April 05 From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada Member No.: 3,931 Region Association: Pacific Northwest |
Porsche recommends the collapsible spare be replaced every few years. I saw my friends 2004 Cayenne spare inflate and push sideways off the rim instead of inflating directly over the rim. We deflated it and stood on the rim to hold the tire down. It lifted us off the ground as one side wall inflated correct and the other did not. Completely unusable. If you can find a replacement tire to put on a 914 rim? I think Elliot did this on a 5 lug Fuchs. like this did?? keep watching https://www.youtube.com/watch?v=gNM95duaOvg |
| Mike Bellis |
Dec 12 2014, 08:38 AM
Porsche recommends the collapsible spare be replaced every few years. I saw my friends 2004 Cayenne spare inflate and push sideways off the rim instead of inflating directly over the rim. We deflated it and stood on the rim to hold the tire down. It lifted us off the ground as one side wall inflated correct and the other did not. Completely unusable. If you can find a replacement tire to put on a 914 rim? I think Elliot did this on a 5 lug Fuchs. like this did?? keep watching https://www.youtube.com/watch?v=gNM95duaOvg Exactly! https://www.youtube.com/watch?v=gNM95duaOvg |
| EdwardBlume |
Dec 12 2014, 08:44 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,340 Joined: 2-January 03 From: SLO Member No.: 81 Region Association: Central California
I had to inflate my 993 spare and it pushed straight out above the rim, but then again, it took 20 minutes in inflate.
| Mark Henry |
Dec 12 2014, 09:29 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
Porsche recommends the collapsible spare be replaced every few years. I saw my friends 2004 Cayenne spare inflate and push sideways off the rim instead of inflating directly over the rim. We deflated it and stood on the rim to hold the tire down. It lifted us off the ground as one side wall inflated correct and the other did not. Completely unusable. If you can find a replacement tire to put on a 914 rim? I think Elliot did this on a 5 lug Fuchs. Seems like many do this but the straighten up once they get full. Did you just not wait long enough to straighten out? I have one from a 944turbo, still need to get a 12v pump. |
| 76-914 |
Dec 12 2014, 10:01 AM
OK, sounds as if I need to get a 911. 993 or 994 rim then purchase a 15" collapsible tire, have it mounted on a rim and carry a 12v pump on board.
| Mark Henry |
Dec 12 2014, 10:57 AM
The tire itself likely will mount on any rim, but mine has two valves. I think the one helps with deflation.
| bdstone914 |
Dec 12 2014, 11:09 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,415 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
| Elliot Cannon |
Dec 12 2014, 02:24 PM
This works for pumping up a spare. First stage of a SCUBA regulator drops pressure to about 120 psi. It will inflate the spare a lot faster than a 12 volt pump. Only problem is, at most places they want to see a SCUBA Cert. card before they will fill the bottle for you.
| ClayPerrine |
Dec 12 2014, 03:09 PM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,568 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
I found that the 15" collapsible spare won't work if you have Boxster calipers. So I got a Boxster spare. (IMG:style_emoticons/default/biggrin.gif)
Those old collapsible spares are unsafe anyway. Even if they have never been used, they are probably dry rotted by now. |
| RenoRoger |
Dec 12 2014, 03:18 PM
Member ![]() ![]() Group: Members Posts: 96 Joined: 11-November 10 From: Reno, NV Member No.: 12,370 Region Association: Northern California
This works for pumping up a spare. First stage of a SCUBA regulator drops pressure to about 120 psi. It will inflate the spare a lot faster than a 12 volt pump. Only problem is, at most places they want to see a SCUBA Cert. card before they will fill the bottle for you. My 912E has a collapsible spare. Most 12volt pumps are PITA. It takes forever to get the tire pumped up and those pumps frequently fail e.g. those from Harbor Freight. I went to Walmart and bought a high volume bicycle pump for $10. Timing myself, I filled the Porsche tire in 5 minutes to 25psi, the recommended pressure, faster than many of the 12 volt electrics. Good exercise for a senior citizen. |
| Mike Bellis |
Dec 12 2014, 11:15 PM
Seems like many do this but the straighten up once they get full. Did you just not wait long enough to straighten out? We took it to the dealer (2 blocks from the flat tire) and the service dept could not get it to inflate correctly. They did lend us a POS loaner wheel to get home. |
Lo-Fi Version | Time is now: 23rd October 2026 - 03:11 PM |
