| Maltese Falcon |
Dec 12 2014, 12:24 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,236 Joined: 14-September 04 From: Mulholland SoCal Member No.: 2,755 Region Association: None |
Chime in if you've experienced the welding/ non welding of these laser-cut slots in the stiffening kits. Looks like these are just for break-bends, but the torch is hot now (IMG:style_emoticons/default/welder.gif)
Thanks ! |
| GeorgeRud |
Dec 12 2014, 01:38 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Seems like there's quite a gap between the reinforcement panel and the trailing arm due to the differences in radius. You could certainly run a bead to close them up at least and that should strengthen the trailing arm. JMHO!
| ThePaintedMan |
Dec 12 2014, 01:43 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,887 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States
Nice jig and really pretty rosette welds!
| Elliot Cannon |
Dec 12 2014, 02:06 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None
Is there any concern about moisture inside the slots? Also, if you make the trailing arms super strong and hit a curb or berm etc., that instead of the trailing arm bending (that is easily replaced) you will damage the chassis where the trailing arm is mounted? Just curious. Also, how does and old guy like you make such nice welds? I've about given up with my TIG machine because my hand ain't as steady as it once was. (IMG:style_emoticons/default/av-943.gif)
Cheers, Elliot |
| Maltese Falcon |
Dec 12 2014, 09:30 PM
I can just get this xacto blade into the slot, an .035 weld wire will never fully get into this area and penetrate the base metal ( .035 mig wire is next is the knife). I'll have the arms powder coated and all the laser- slots will get sealed up. The back half of this racer is getting a complete going over with extra steel, strengthening, welding. If I'm unlucky enough to bend or break something...I'll make it even stronger (IMG:style_emoticons/default/blowtorch.gif)
Thanks guys for your tips. Elliot...welding is like flying; you learn it, it's rewarding and you can have fun ! Better with age because "Old guys Rule "! Marty |
| Jeff Hail |
Dec 12 2014, 09:42 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
Marty
Weld up the slots and make them look nice. With a 1000 hp the arms need to be strong. With a 1000 hp the stock suspension mounting is well going to break anyways so order Foleys pick up kit and do a "while your in there" |
| Maltese Falcon |
Dec 12 2014, 10:09 PM
Marty Weld up the slots and make them look nice. With a 1000 hp the arms need to be strong. With a 1000 hp the stock suspension mounting is well going to break anyways so order Foleys pick up kit and do a "while your in there" Yes Chris sure is the go to guy on 914 chassis equip. We have him on speed dial, and he is good to deal with. I still like to overkill the parts with more strength. I like the way you think so I handed off the slot welding to the night shift ! I'll detail tomorrow. Old guys gotta rest up Friday nights. Marty |
| r_towle |
Dec 12 2014, 11:16 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
I would agree on all counts.
Weld it up 1000 HP is gonna do damage. Powder coating is good Old guys do rule Elliott is shaky |
| euro911 |
Dec 13 2014, 12:36 AM
Retired & living the dream. God help me if I wake up! ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,937 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California
If for no other good reason, I'd think that welding them shut would keep moisture from getting in there.
I don't shake (yet) ... guess I'm not old enough (IMG:style_emoticons/default/poke.gif) |
Lo-Fi Version | Time is now: 1st May 2026 - 05:26 AM |
