| Harpo |
Dec 13 2014, 02:17 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
| dlee6204 |
Dec 13 2014, 02:26 PM
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
There is a small tab on the terminal that holds the terminals in place. I usually use a small screw driver or pick to push the tab in and free the terminal. You would have to stick it in from the front of the connector IIRC.
| JeffBowlsby |
Dec 13 2014, 02:29 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,378 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Not all wire terminals have tangs, but for those that do:
| toolguy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,277 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California
There is a little tab that bends up on the side of the copper connector. . It catches the lip inside the plastic housing. . There is a 'correct tool' to release them but a tiny jewelers screwdriver will work. .
Look inside and see where it is, insert the screwdriver and depress the tab until it passes the lip in the housing. . and pull out the copper connector. . If you have to force it, you don't have the tab depressed enough. . they come out easily. |
| bdstone914 |
Dec 13 2014, 02:41 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,422 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
On the flat side of the connector there is a tab that has to be depress to remove the terminals. I use a small paddle shaped dental tool to remove them.
You can make a tool by flattening a piece of thin stiff wire. |
| Harpo |
Dec 13 2014, 02:44 PM
This is what I love about 914world, there are always very helpful people to answer my dumb questions
Thanks guys David |
| TheCabinetmaker |
Dec 13 2014, 03:07 PM
I drive my car everyday ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,378 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
Nice pic Jeff. Kinda says it all.
| toadman |
Dec 13 2014, 04:05 PM
Member ![]() ![]() Group: Members Posts: 168 Joined: 26-December 05 From: Cincinnati, OH Member No.: 5,316 |
Years ago I purchased a tool just for this purpose. It was made by Lisle and I bought it at CarQuest. It works really well. I have had no casualties.
I checked the Carquest website and they have a 3-piece set of these tools, but not the single one I bought. If you want to take a look, the 3-piece set is PN 57750. You may find the single tool if you search a little more. |
| TheCabinetmaker |
Dec 13 2014, 04:43 PM
Years ago I purchased a tool just for this purpose. It was made by Lisle and I bought it at CarQuest. It works really well. I have had no casualties. I checked the Carquest website and they have a 3-piece set of these tools, but not the single one I bought. If you want to take a look, the 3-piece set is PN 57750. You may find the single tool if you search a little more. I use a simple cotter pin with one end ground to fit then throw it away cause I'll lose it anyway! |
Lo-Fi Version | Time is now: 3rd November 2026 - 11:23 AM |
