engine size calculator, matrix |
Randal |
Feb 3 2005, 11:13 AM
Advanced Member Group: Members Posts: 4,446 Joined: 29-May 03 From: Los Altos, CA Member No.: 750 |
I'm looking for a link to an engine size calculator (in cc's) that shows all possible combinations of cc's based upon different crank and piston sizes for a Type IV.
I've seen this matrix several times on the web, but can't find it today. |
ArtechnikA |
Feb 3 2005, 11:31 AM
rich herzog Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
engine displacement == cylinder displacement * number of cylinders
cylinder displacement == area of cylinder * stroke area of cylinder == pi * r**2 (3.1415926535 * (diameter/2 * diameter/2) eg: 80mm bore, 66mm stroke, 6 cyl radius of bore 40mm r**2 == 1600 * pi == 5026.5 * stroke == 331752 * cylinders == 1990513 that's cubic mm -- divide by 1000 for cc 1990.5 (popularly called 1991cc |
eeyore |
Feb 3 2005, 12:15 PM
Senior Member Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None |
Stuff
Attached image(s) |
Randal |
Feb 3 2005, 12:17 PM
Thanks Folks. I love this site.
Britain Smith |
Feb 3 2005, 12:29 PM
Nano Member Group: Members Posts: 2,354 Joined: 27-February 03 From: Hillsboro, OR Member No.: 364 |
I also have an extensive one that I worked on with Brad that calculated all sorts on things.
How do you attach an excel file. -Britain |
eeyore |
Feb 3 2005, 12:55 PM
Oops. The Excel file don't download right, so I whacked the post.
The formula is =3.1415*({bore in mm}/10/2)^2*{stroke in mm}A2/10*4 |
Lo-Fi Version | Time is now: 7th June 2024 - 04:42 AM |
