Additional caliper for ebrake setup |
got914? |
Dec 24 2014, 04:21 PM
Member Group: Members Posts: 133 Joined: 8-October 14 From: Niagara Member No.: 17,993 Region Association: None |
Was looking at the rear and trying to see if an additional caliper from say an rx7 for a hydro ebrake setup would be possible.
Anybody ever toy with the thought of this ? |
mgp4591 |
Dec 24 2014, 04:26 PM
914 Guru Group: Members Posts: 5,383 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
Was looking at the rear and trying to see if an additional caliper from say an rx7 for a hydro ebrake setup would be possible. Anybody ever toy with the thought of this ? Someone awhile back posted a pic of an electric actuated e-brake caliper. I know in Utah you can't have a hydraulic e-brake- I thought once about using a Mico lock for e-brake and the state code says it needs to be mechanical, but that's for modern vehicles and may not apply to a vintage registered car. Anyone have info on the electric parking brake option? |
type47 |
Dec 24 2014, 04:30 PM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
What's the matter w/ stock? Send the calipers to Eric Shea at PMB Performance in UT. His products will make for an easy solution to whatever problems you are having.
Mike Bellis |
Dec 24 2014, 06:14 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I'm planning to run a Wilwood Spot Caliper (12 O'Clock). It's on the list for 2015. I have the parts to make this electronically actuated but you could use the stock E brake handle. They are pretty cheap for a universal solution. They are available in various rotor widths.
Mark Henry |
Dec 24 2014, 09:42 PM
mgp4591 |
Dec 25 2014, 12:01 AM
I'm planning to run a Wilwood Spot Caliper (12 O'Clock). It's on the list for 2015. I have the parts to make this electronically actuated but you could use the stock E brake handle. They are pretty cheap for a universal solution. They are available in various rotor widths. Being a universal type, does it come with an easily adaptable bracket? Looks sweet and just the ticket! (IMG:style_emoticons/default/idea.gif) |
ClayPerrine |
Dec 25 2014, 07:22 AM
Life's been good to me so far..... Group: Admin Posts: 15,518 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I'm planning to run a Wilwood Spot Caliper (12 O'Clock). It's on the list for 2015. I have the parts to make this electronically actuated but you could use the stock E brake handle. They are pretty cheap for a universal solution. They are available in various rotor widths. Being a universal type, does it come with an easily adaptable bracket? Looks sweet and just the ticket! (IMG:style_emoticons/default/idea.gif) I built a bracket for this setup years ago, but never ran them on the street. The late Wes Hildreth put a pair of them on one of Mike Floyd's 914s. Mike quickly found out that if you set the park brake when hot, you have to jack the car up, pull the wheel, and hammer the hell out of the park brake caliper to get it to release. I was at Wes' shop when Mike demonstrated it. If you look on Wilwood's site, you will notice that even they stopped selling them for use as a park brake in their kits. They went to the small drum brake like a 911. (IMG:http://www.914world.com/bbs2/uploads_offsite/www.wilwood.com-1143-1419514151.1.jpg) Hopefully Mike will chime in here with some first hand experience. |
old914dog |
Dec 25 2014, 07:59 AM
Member Group: Members Posts: 72 Joined: 28-August 04 From: dallas,tx Member No.: 2,643 Region Association: None |
Amen and Amen!!
Wes spent hours and hours to rig the linkage..heim joints, threaded rods, etc. WE trashed it all and installed the 911 backing plate, shoes and set up the cable to actuate. There are differing opinions about the use of one butterfly vs. two in order to spread the shoes. I like the "backup plan" of having both. There are several threads detailing the install. Merry Christmas old914dog mike |
pdlightning |
Dec 26 2014, 11:41 PM
Member Group: Members Posts: 207 Joined: 4-February 11 From: Santa Clarita Member No.: 12,660 Region Association: Southern California |
What's the matter w/ stock? Send the calipers to Eric Shea at PMB Performance in UT. His products will make for an easy solution to whatever problems you are having. I second the Eric Shea recommendation. I purchased the 308 calipers and they are beautiful. Nice set up and good engineering! |
a914622 |
Dec 27 2014, 11:39 PM
Member Group: Members Posts: 316 Joined: 12-August 10 From: northwest Member No.: 12,048 Region Association: Pacific Northwest |
Not to muddy the waters but the rear fords have a very good rear caliper with ebrake like the vw setup. Both in 14mm rotors and the 22mm vented ones. I was looking at the vented calipers from a turbo coupe, same as Lincoln , for a vanagon brake setup. I ended up using eurovan 12mm rotors and the Audi calipers.
The late model S-Audi should have a vented rear as well but I don't know the rotor thickness . Jcl |
Lo-Fi Version | Time is now: 8th June 2024 - 09:46 PM |
